Activity Forums Square Box CatDV Is it possible to BUILD THE PROXY OF A SELECTION OF FILES?
  • Is it possible to BUILD THE PROXY OF A SELECTION OF FILES?
    Posted by Carla Vidal on January 22, 2013 at 3:02 pm
    I have like 100 files to which I have to create its proxy. I have to do it manually one by one because otherwise, it only does the first file. What am I doing wrong? Thank you 🙂
    Bryson Jones replied 13 years, 7 months ago 2 Members · 3 Replies
  • Bryson Jones
    January 22, 2013 at 4:26 pm
    First Rule of CatDV:
    “Try it on a test set of data.”
    Your answer is yes. We regularly fire proxy jobs of thousands of clips at once on large systems.
    Note that on the client app, you should test to see how fast your system makes proxy so you don’t choose 400 hours of proxy to create.
    Part of the magic of CatDV is the ability to do operations on hundreds of clips at once, tagging, proxy creation, renaming etc..
    bryson
    bryson “at” northshoreautomation.com
  • Carla Vidal
    January 23, 2013 at 8:16 am
    But every time I select more than one clip and click “Build proxy movies”, an error occurs with the rest of them… how can I do it? I appreciate your help. Thank you,
  • Bryson Jones
    January 23, 2013 at 5:29 pm
    This is something you should contact tech support with. It’s not the usual behavior.
    bryson
