Activity Forums Adobe After Effects Is it possible to “animate” the font type?
  • Is it possible to “animate” the font type?
    Posted by Noizzz on December 26, 2005 at 10:00 am
    Hello,
    Is it possible to “animate” the font type? I’d like to flip fonts after each couple of frames. A bit like the
    “buzz words” text animation preset, but flippin fonts instead of different words. Is this possible at all? Is
    there an expression that handles fonts? Is there a “raw” version that just lfips between al the fonts every
    single frame randomly?
    Thanx
    Bart
    Canwal Brar replied 20 years, 9 months ago 3 Members · 2 Replies
  • Mylenium
    December 26, 2005 at 10:33 am
    Nope, you can’t access font face and several other font related info with scripts and expressions. You will have to do it manually by creating keyframes on the source text property. You could also check Digital Anarchy’s Font Hacker plugin, which may do the trick but of course isn’t as elegant as using AE’s native text tools.
    Mylenium
    [Pour Myl
  • Canwal Brar
    December 27, 2005 at 10:25 am
    this is little tricky part infact i dont know exact solution to your
    problem may be you have to do it manually.
    but if you could use a software called as BLUFFTITLER
    it is exclusively known for this feature of changing font types.
    canwal brar
