Activity Forums Apple Final Cut Pro Legacy is it possible to add shot number/text with out having to render?
  • is it possible to add shot number/text with out having to render?
    Posted by Christina Rule on December 19, 2008 at 6:13 pm
    I am not sure if there is anyways around this or not, but basically I need to add a shot number to each clip in my seq.(so that it is visible when I render it out) Right now I am just using Text overlay. But I have to render it out… I didn’t know if there was a better way to do this? Also With transitions FCP always makes me render them out before I can edit in real time?
    http://www.christinarule.com
    Christina Rule replied 17 years, 8 months ago 2 Members · 2 Replies
  • Shane Ross
    December 19, 2008 at 6:25 pm
    Sorry, no way to add text without rendering before output. Well, they will be dark green (should be…no red bar) so you can play it out to tape. But if you need to encode that as a file, it will require rendering.
    Render transistions? What codec is your footage?
    Shane
  • Christina Rule
    December 19, 2008 at 8:07 pm
    there is a red bar over it when i add the text. Thats what I dont understand. The footage is actually render out of Maya. But its exported as 1280 by 720. 30 fps. Aja cona 2vuy compressor
