Activity Forums Adobe Photoshop Is it possible to add a drop shadow to a masked image without it creating a rectangle?
  • Is it possible to add a drop shadow to a masked image without it creating a rectangle?
    Posted by Tia Bradford on June 26, 2010 at 7:57 pm
    Hello,
    I have a single image that is isolated on a white background. I used the color range tool to make a selection and create a mask over the white background. So the object looks totally isolated when I move it on top of another background.
    I need to add a drop shadow to this object, so that when it is placed over the new background it looks like it is floating with a shadow underneath. When I add the drop shadow it looks fine around the actual object, but it also affects the outer edge of the image, so it looks like there is a drop shadow around the bounding rectangle of the image.
    Any ideas on how I can get this to only affect the object and not the border area? Thanks.
    https://drop.io/nbfugcq
    Tia Bradford replied 16 years, 2 months ago 2 Members · 2 Replies
  • Darby Edelen
    July 1, 2010 at 12:22 am
    It sounds like you may have some stray visible pixels hanging around the edge of your image. Try painting this area black in the layer mask.
    Darby Edelen
  • Tia Bradford
    July 1, 2010 at 12:50 am
    Thank you very much. Yes this was the problem. There was 1 px outline around the image that was impossible to see because it was the same color as the background.
    Much appreciated!
