Is it my bleary eyes, or is that picture fuzzy?
I don’t get it. I’ve owned, engineered and maintained everything from Matrox Digisuite to Avid Symphony…Linear Online to Media 100..and I thought I knew how these things work. But the way FCP with Kona3 handles resolution in the timeline simply baffles me.
When I capture SD Uncompressed 8 bit and use the same sequence settings, I add a dissolve (transition) to a clip and the resolution drops at the transition point to something like DV25. But if I add a blank text effect over the top of the whole thing, then the resolution stays clear. Are there two (or more?) paths to effects processing?
When I work in HDV and try to export a clip to work on it in After Effects, it sometimes changes color space or field order before it gets back to FCP. And when I export pristine (Apple None codec) GFX originating from AE, they get soft when they are put on the FCP timeline.
I’ve surfed through the preferences and system settings and even the 8 inch thick set of manuals, but I am having trouble finding anything that relates directly to this Kona3 system and the problems I am seeing.
Does anyone know of a clear and concise documentation or a primer for this system that will keep me out of the weeds?
For that matter, a clear explanation of the relationships between pixel dimensions, aspect ratios and color space as files are moved from one app to another. Wrangling resolutions and compression schemes sometimes takes all the joy out of the creative process. It sends me into techie-geek mode, then all my creative juices start to dry up.
Any input from you gurus out there is very much appreciated.
