Activity Forums Apple Final Cut Pro Legacy Is it hard to convert footage from 720p 60fps to 24fps?
  • Is it hard to convert footage from 720p 60fps to 24fps?
    Posted by Noam Osband on August 9, 2011 at 4:20 pm
    I use an HMC-150 and am thinking of shooting a project that I want in 24fps. Sometimes I want to do slo-mo, so I was thinking of shooting the whole thing in 60fps, and for all the bits that are not slow-mo, just changing the video to 24fps. I want to do this as it will give me the option of perhaps going to 30fps for the project which is not what I want to do, but I do wonder how things will look with much of the 30fps archival footage I have.
    My question: is it easy to go from 60fps to 24fps with FCP7?
    Noam Osband replied 15 years, 1 month ago 3 Members · 3 Replies
  • Alan Okey
    August 9, 2011 at 4:36 pm
    If you want slow motion, use Cinema Tools to conform the 720p60 footage to 720p24, then import the conformed clips into FCP. Only do this on copies of the original clips, because it is a destructive process. Also, be aware that Cinema Tools can only conform source footage with intraframe codecs (DVCPRO HD, ProRes), not long-GOP interframe codecs (XDCAM EX, HDV, etc.).
  • Shane Ross
    August 9, 2011 at 7:26 pm
    It is quick and easy, but you can make a mistake pretty easily…so DUPLICATE the clip you want to convert to slow motion first. Well, convert to proRes first with Log and Transfer, then duplicate the clip, THEN conform with Cinema Tools.
    I have a tutorial:
    https://library.creativecow.net/ross_shane/slow-motion_cinema-tools/1
    Shane
  • Noam Osband
    August 10, 2011 at 9:19 pm
    Is it just as simple/viable to turn it into 30fps when I use it into FCP?
