Activity › Forums › VEGAS Pro › Is it better to simply use dual layer dvd’s as opposed to messing around w bitrates?
Posted by Jeff David on March 12, 2019 at 9:28 pmI have a 8.5 gb project that I want to burn to a dvd.
Is it better to simply use a dual layer dvd or should I mess around w the bitrates?
I was sent instructions on bit rates but it seems easier to simply use a dual layer dvd?
Lenovo quad core i7 16gb of ram, Windows 8.1 MS 13 64 bit Thumbnail is view out of the Olde North Church window where the signal lanterns were hung, as in, \”1 if by land 2 if by sea\” looking across the Charles River to the Charlestown Naval Yard where rebels awaited the signal April 18th, 1775.
Graham Bernard replied 7 years, 2 months ago 4 Members · 20 Replies -
George Dean
March 12, 2019 at 9:56 pmHi Jeff,
I would try the bit rate adjustment and if I could live with the quality I would avoid dual layer, as sometimes players have an issue with dual layer burns.
Best Regards……George
Graham Bernard
March 13, 2019 at 7:59 am[George Dean] “I would try the bit rate adjustment”
In a heart beat… In a heart beat.
Once you’ve experimented with adjusting BitRates, and getting all your Video onto one DVD you’ll have a world of opportunity. What is the total Playtime of your Movie? I can easily get two hours onto a single, single layer DVD, including complex menu structures etc etc….
* Grazie
Cameras: Canon XF300 + PowerShot SX60HS Bridge -
Francois Pénzes
March 13, 2019 at 12:57 pmHi Jeff
I second my colleagues. You can use this handy calculator to help you figure it out. This is one of many available for free out there.
https://www.videohelp.com/software/Bitrate-calculator
Cheers !
PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
Cameras: Canon XF305 + Canon XH-A1
Blackmagic HyperDeck Studio Mini
Vegas Pro 16, User since Vegas 3.0\’\’When the cutting stops, the editing begins…\’\’
Jeff David
March 27, 2019 at 1:44 amThanks! My video is 2 hours long.
Jeff David
March 27, 2019 at 2:09 amThanks Francois.
I downloaded the calculator but I am somewhat confused.
For the video specs, I know I can look them up under “project properties” and I did except I was unable to find
“TOTAL FRAMES”
I am using Sony Movie Studio Platinum 13. Where do I find the number of frames please?
Also – where do I find the bitrate and size for the audio tracks? I have a voice track and sound track.
Am I correct that on the right hand side under “CALCULATE FROM” I only need to enter the final size I want?
I see that 1,457 is entered in the video bitrate option and 0.001 is entered in the bits/pixel farm field. Do I need to enter anything in those boxes?
I’ve never had any experience w this type of thing.
Thanks.
Graham Bernard
March 27, 2019 at 4:08 am[Jeff David] “My video is 2 hours long.”
Totally doable. Now, that BitRate calculator is not one I know. Here’s the one I’ve used over decades of use and found to be both reliable and straightforward. It also gives a graphical suggestion as to the possible Quality you’d get.
It’s part of this “other” COW thread being hosted by a stalwart for VP, John Cline, a chap who I’ve learnt much of my video production, from capture to publishing – here that means DVD production. Thanks John! ???? : https://forums.creativecow.net/docs/forums/post.php?forumid=24&postid=935307&univpostid=935307&pview=t
Jeff, if you remember anything recognise the following:
1) Higher BitRates create larger files. If your video contains noisy footage eg Fireworks; dusty effects; sparkles from welding torches and so on, you might need to apply, just for that section, MPEG2 renders for that footage. BUT if your footage is mostly low optical noise or “quiet” then we can contemplate a lower BitRate.
2) Whilst Variable BitRates (VBR), as opposed to a Constant BitRate (CBR), whilst (VBR) allowing us to be “mean” with file size might confuse older DVD players as they could struggle adjusting to decode the bit variations.
Now, also download BitRate Viewer, although old, it still works. What this does is to allow us to see the changes in the bitrates of a file and give us a clue what’s best to use: https://www.videohelp.com/software/Bitrate-Viewer-2
So, with these two tools:
* BitRate Calculator (see the COW link to John Cline site above)
* BitRate Viewer (see the VideoHelp link above)You can comfortably, subject to any necessary wrangling of optical noise, fit your TWO HOUR material onto a single DVD. No need for Dual Layer DVDs.
* Grazie
Jeff David
March 27, 2019 at 7:49 pmThanks a million! I’m going to study your links now and see if I can figure out how to do it.
I don’t understand the one that Francois sent – although it’s prob pretty simple if you’re not a novice like me.
Wow – I’m glad I don’t have any fireworks like stuff as that seems like ti would be difficult to combine mpeg2 in there. Wow. I’m glad I don’t have to do that – it seems complicated.
I’ll let you know how I make out after studying your links!
Jeff
Jeff David
March 27, 2019 at 8:43 pmThanks Graham,
I downloaded both programs.
I saw where the poster said what to put in some of the fields on the bitrate calculator but what about:
Motion Menus running time
fixed menus
nr of subtitles
total slides
Menu transitions
streams per vts
duration eachdo I have to put anyhting in those fields? I have no idea where I would get that info??
Graham Bernard
March 27, 2019 at 9:16 pm[Jeff David] “do I have to put anyhting in those fields?”
Quick reply – no. Unless…. you’ve designed a whole bunch from that list. Have you? But, just for starters, let’s get an overall calculation and think about those overheads later, yeah?
Get used to Tweaking your “recipe”, making changes to balance all into that 4.7gb. As you adjust you’ll find you can drive down your overall size to provide some overhead space. It’s great fun!
Oh yes, whenever I’m preparing and doing draft DVD Burns I do it on DVD-RW.
* Grazie
Jeff David
March 28, 2019 at 8:08 pmThanks a million Graham?
I just spent the afternoon training to be able to do the dvd burn.
I would not have been able to figure it out just based on just the bit rate calculator but I found this awesome complimentary training video that is fantastic and covers the entire process!
https://www.youtube.com/watch?v=rHBHsY2qdd8
I’ve yet to attempt to burn the dvd but that’s the next step!
I’ve burned blu-rays in the past w out any problem but it seems dvd’s are more involved.
I only just realized from reading the links that most organizations don’t even have blu-rays! Wow- I figured they would all have state of the art but I found out different!
Thanks again!
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
