Activity Forums Apple Motion Is it a plugin for FCP, Motion Behavior or keyfreamed animation ?
  • Is it a plugin for FCP, Motion Behavior or keyfreamed animation ?
    Posted by Fredy Schwerdtner on January 6, 2010 at 5:59 pm
    Hi everybody … I am starting a production which we will insert some images ( vector drawings, photos and some other kind of images ) and we would like to make an effect that is used in a video we found in this link : https://www.youtube.com/watch?v=lgmTfPzLl4E
    Is it a behavior as the ones used on Motion or plugins used on FCP ?
    Thanks a lot in advance.
    MacBook Pro 17″
    2.5 GHz Intel Core 2 Duo
    4GB 667 MHz DDR2 SDRAM
    (2) External HD LaCieMac (400/800 FW and USB)with 500GB -(2) USB External HD Western Digital (in cases) with 750GB
    OS X 10.5.7
    Final Cut Studio 2
    Stephen Smith replied 16 years, 8 months ago 2 Members · 5 Replies
  • Stephen Smith
    January 6, 2010 at 6:08 pm
    Which effect are you talking about. Can you give us the time in the video that it occurs at?
    Utah Video Productions
    Check out my Motion Tutorials
  • Fredy Schwerdtner
    January 6, 2010 at 6:54 pm
    It practicaly occurs all over the video. You can see it beggining at 00:43 . I’m talking about the blinking / shaking and little distortion of the drawings.
    MacBook Pro 17″
    OS X 10.5.7
    Final Cut Studio 2
  • Stephen Smith
    January 6, 2010 at 7:16 pm
    Got it. Check out the Wriggle behavior. Go to Add Behavior, Parameter, Wriggle. Change the Apply To section to: Transform, Position. Drop the Amount to about 4 and you will get a nice jerk in the objects movement. You can do the same for the Opacity but I think you will like the Randomize option better. Go to Add Behavior, Parameter, Randomize. Change the Apply To section to:Object, Opacity. This should get you started. Mess around with the settings and other Parameter Behaviors if you like. Best of luck and hope this helps.
  • Fredy Schwerdtner
    January 6, 2010 at 7:42 pm
    Thanks a lot Stephen. I will let you know how it worked out !
    MacBook Pro 17″
    OS X 10.5.7
    Final Cut Studio 2
  • Stephen Smith
    January 6, 2010 at 7:46 pm
    Sweet, happy to help. It sounds like this is going to be a fun project.
