Is HD-24p 1280×720 good enough? Indie Movies & Documentaries
Posted by Alan Andrews on September 7, 2009 at 4:18 pmI’m somewhat a newbie to video prodcution and using vegas 9.0.
I just purchased a Canon HF11 and also have a panasonic lumix TX5 digi cam which offers some great video @ 1280×720. Ok they are not prosumer cams but with creative thinking, I get some good video and people were impressed with my guy ritchie type clips I produced.
I started making some short indie type films with not bad results at all. But now need to get the clear answer to filming/rendering and resolution etc. This subject I know can get huge in itself but I am trying for now to get a simple plan for my movies.
On my first projects I used HD 1080-24p (1920×1080) but not sure if that is overkill for the what the human eye sees anyhow?
Is HDV 720-24p (1280 x 720) good enough to produce a movie like video that would display on say a 42″ wide screen TV?
I was considering rendering as WMV 4.8mbps hd 720-24p ??
I am just thinking that I am wasting time and space recording MXP super high Q vids on the HF11 and thought I could drop the quality and still get a good output?
I also notice when I check the properties of an MTS file using MXP quality it says 1990x180x12 (what’s with the 12?? why is this not 24?). My Lumix clips (MOV files) properties are 1280x720x24
If anyone has some basic tips without over-digesting the subject I would GREATLY appreciate it.
My OBJECTIVE:
Produce a quality enough video/film to show on a large wide screen TV. Good enough for the human eye to watch.
Keep clip sizes down to speed up import & editing processes.
Efficient overall rendering speeds (I understand FX etc will slow this down)
Determin a project standard for camera(s) and vegas which I know I can use to make films and documentaries and confident the output will be kind to the eye.There are 1000’s of useful tips and pointers but I am trying to get the basic “Do this ..” approach.
I’ll get my prosumer camera in the future 🙂
Thank you all for your help, these boards are a great asset for getting to grips with film making on a budget.
AlanAlan Andrews replied 16 years, 11 months ago 4 Members · 14 Replies -
D. Eric franks
September 9, 2009 at 2:21 pmLots of great questions, so I’m pretty confident you’ve got this worked out. Just a couple of comments:
(1) I’d shoot as high-res as you can. You can always down-scale, but upscaling is always a losing proposition, however…
(2) 720p is a great format that will be fine anyhow, especially for distribution on the Internet and computers in general. Besides this being the current base HD format on YouTube, Vimeo, et al, it’ll also fit on more computer screens (not everyone is running around with 1080p laptops!). Even so…
(3) I’d still shoot in 1080p. See #1.
(4) I’d also max the quality on the camera and not worry about space. Memory cards are pretty cheap, so I’d go grab another one. Once again, you can always down-sample quality, but you can never ever go the other direction.
(5) I’m not certain what the crazy “1990x180x12” format is, but I know what it means: 1990 across, 180 up and down (really narrow!) and 12-bit color (kinda strange, but not outrageous). 1920×1080@24 is pretty standard 8-bit per channel color.
As to your OBJECTIVE (and a little summary), I’d say that you cannot maximize quality and minimize file size at the same time. You can either compromise with mediocre quality and medium-sized files or you can pick one or the other. My recommendation is that you get more memory cards/HDD space and don’t worry about file size and efficiency. Go for maximum quality source/edit and don’t worry about render times. Render overnight. Render when you’re watching TV. Render during dinner. Use render times to play XBox or post on the CCow.
Now, when you get to distribution, THEN you need to figure out a reasonable compromise between file size and quality, but that is a whole other post…
_____________
“The length of a film should be directly related
to the endurance of the human bladder.”
— Alfred Hitchcock
https://videopia.org -
Alan Andrews
September 9, 2009 at 3:22 pmThanks Eric, clear & good answers and maybe obvious after more researching of the whole issue myself 🙂
I did some further testing, recording with various bit rates and formats and then did some editing/rendering etc. 9/10 planning 1/10 work I guess ;-). Thats the IT professional side in me.
I found pretty much the same conclusions:
I now decided to record in 24P (cinemode) at the 1080p res using 12kbps (known as SP+ on the Canon HF11). The difference to the eye is very neglible between MXP & SP+. I actually might go 17kbps to be sure but I dont think the MXP is really offering a huge improvement unless I was videoing a fleas bollox. The file size difference between MXP & SP is about 3 to 1. File ratio between MXP & SP+ about 2 to 1.
Space is not a major issue but it adds some accounted efficiency doing data transfers.I ran some video tests and rendered WMV at 6.8 1080 and 720p and saw nothing major such that the eye could detect differences (unless this was a scientific analysis). The eyes can be fooled when the movie is rolling along. Good scripting & good timing I think play a major part here, though I’m not a qualified film maker I say this from common sense and creative thought.
To improve rendering/editing and review times Do you know if the following idea hurts the video quality?
I thought to render satisfactory takes including all and any FX to sectional WMV files then sticth these together in a larger edit thus having the video compiled without all the FX processes to deal with: Render say at 1080p so its quality.
Reason for this is obvious, the previewing etc is all slow. I am thinking to do the network rendering, so I can work on other parts then do the “stitching” (is this a correct term?) as another edit.
Another point to this is even though I have plenty space I have many redundant files. Some I’ll keep for stock footage, but most I want to shred to keep my archives lean.
I have yet to find a reliable previewer for the MTS files. Just about everything sucks beside viewing direct from the camcorder (screen or TV hookup) BUT I cannot find simple way to index the files for reference. Right now I preview them either with VLC or within Vegas (neither produce a smooth strem preview). I go shoot many different parts/scenes and yes maybe I should list on a scene chart, but still the cam has no real easy way to give me the file reference. (name xxx, date & time this is not a great cross reference). I wish some smart fella would write a quick & dirty previewer program so I can QUICKLY view/thumbnail the 100’s of takes then pull what I need. I am planning to get a Class 4 SD card, and habitually train myself to record to that and use the internal cam memory for odd bits. Anyway ignore this bit of a rant, I digress.
Thanks for your input I’m sure there’s more from me to come.
Cheers
Alan -
D. Eric franks
September 9, 2009 at 10:14 pmIf you’ll let me toggle Old Man Mode on:
Why, back in my day, we didn’t have real time previews. And a 3 minute video took all night to render. And we had to walk to the studio in the snow in bare feet.
Ahem. OK, so the last bit is untrue, but it might illustrate why I am not at all bothered by large files, “slow” transfer times and long renders. And it might explain why I still recommend recording at maximum quality: you never know when a flea’s naughty bits are gonna be important and you will regret the lower quality mode.
As to slow transfers, why, in my day, data transfers happened in real time. You shot an hour of video? That took an hour to transfer. Oh, sorry, forgot to turn Old Man Mode back off…
Anyhow, I’m a nightmare as far as disk organization goes, so don’t listen to a word I say on that. My solution to inefficiency is to buy new hard disks all the time.
OK, now the two interesting parts:
(1) Workflow: MTS and other modern, highly compressed H.264 files are incredibly computationally intensive and do not play nicely with even the latest muscular computers. Next gen computers will be better, but by then, the camera people will have figured out a new “better” format to mess with us. I would just give up on realtime previews, learn to live with lower preview quality and, when necessary, SHIFT+B to render small sections to RAM to check the quality of important bits. I’m probably SHIFT+B previewing once every few minutes near the end of a project, checking final tweaks and what not. I definitely would NOT render to a lossy format (like WMV) and then RE-render to stitch it together. Definitely not. You want to keep as few render cycles in your workflow as possible, i.e., one (if you can). If do want to pre-render to speed things up you can (a) render out to a lossless format (QT MOV animation codec – HUUUUUGGGGEEEE files) or (b) Shift+M to selectively render in Vegas 9. Same same, just different technique: your call.
(2) Distribution to WMV at 6Mbps should look very nice at 720p. Personally, I like Main Concept’s H.264/AVC in the MP4 format (a bit more compatible with more computers, maybe looks better, maybe not). Vimeo/YouTube sits at 2Mbps, so you can go that low for really efficient distribution.
Oh, and one more thing: Your observation about planning is exactly spot on. The more time you spend in planning, the more time you will save in production. Now, you won’t actually save any time at all, and, for example, if you spend 2 hours in planning and 1 shooting, you could reverse that to 1 hour of planning and 2 hours of shooting: either way, it’s 3 hours. However, the actually shooting bit is the most difficult part and the most stressful… but it could be the most fun part too, so I’d recommend 2 hours of planning and then a really fun, energetic 1 hour of shooting. If you have that choice. And you should probably listen to what I say and not what I actually do: I never seem to spend enough time planning!
Alan Andrews
September 10, 2009 at 5:46 pmOld Man? Old Man I hear you say ? … hehehe When I was in the mines turning nuts n bolts Eh by gum … Actually I was a coal miner for 13 yrs but thats back in time. 46 yrs on but happy to have been part of it, even the 1984 strike.
Yeah I buy what you say about the rendering Eric. However I did try MP4 (Main Concept’s H.264/AVC ) but this wouldn’t even play when trying to view in QT player and worse in WMP 11. I’m still pretty clueless in this whole codec world its a mass confusion. WMV seemed to give me best and reliable outputs thus far, mayber it was luck? The MP4 was also evil grainy when I brought it into a new project ??
So WMV is lossless then ?? I’m LOST 🙂Being these days an IT consultant (though I am trying to be a video pro now haha) I know all too well about constant change its a real pain for everyone.
I installed the K-Lite codec pack, WMP registry fix and a DLL that thumbnails MOV files (quickthumb.dll). At least now I can thumbnail and preview both MOV & MTS files (2 cameras) so I can sift through my files via explorer to be more selective for my projects.
I always use the Shift+B to do some quick previews to check my FX etc. Great use for it yes.
My laptop is slightly under par AMD Athlon 64 x 2 + 2Gb ram, I plan to get a new machine next mth. Quad core.
Thanks again for your input keep it coming if you have the energy!!
Cheers
Alan -
Alan Andrews
September 10, 2009 at 6:15 pmSorry I Installed VISTA Codec pack NOT K-Lite. This works for XP also
D. Eric franks
September 10, 2009 at 9:52 pmI guess it’s possible that there’s a WMV lossless mode, but I’ve never heard of it. Basically, WMV is just Microsoft’s flavor of H.264, like DivX has there’s and MainConcept and Apple and… Some follow the ITU-T H.264 and ISO/IEC MPEG-4 AVC standards more closely than others and my understanding is that Microsoft mucked about with their version more than other did, but I’ll admit that was just a rumor I heard long ago (probably when I had lunch with the president of MainConcept… KIDDING). Anyhoo, there’s no question WMV is a great codec, but there’s also no question that more standardized MP4 will be more broadly compatible on Windows, OS X, iPods, etc. Ultimately, whatever works, right?
But H.264, by any other name, is not typically implemented as a lossless codec (although I believe that as a part of the spec, it can be). There are a number of lossless options, including Uncompressed AVI and QuickTime using a couple of codecs, like the Animation codec or PNG. I used to use PNG, but it really only offers a slight advantage in file size and is a lot more computationally intensive (read: slower renders), so, once again, I just buy more hard disks (which is also my solution to archives – I know, I’m lazy).
Data rate is going to be the fun part to play with and is almost everything there is to worry about in terms of quality. Again, 2Mbps is YouTube HD (pretty much a good minimum), 4Mbps is going to look very nice, 10Mbps is spectacular and (as you’ve noted) 17-25Mbps is a pretty decent acquisition format.
And, yes, 2 generations ago 2 core CPU laptops are not going to be fun to edit H.264 video on. It’ll even struggle on playback of HD video, much less on editing. Maybe WMV is just easier for Windows to play back? Possible.
Norman Willis
September 11, 2009 at 2:36 pmHi Alan.
I’m not Mr. Expert, but I agree with Eric. Hard drive space is cheap cheap cheap nowadays. Use the larger file size, especially if you are going to get a stronger workhorse.
Norman Willis
http://www.nazareneisrael.org -
Dave Haynie
September 29, 2009 at 9:22 amOk, let’s look here… The HF11 is a good camcorder. Use it if you’re shooting video. The TX5.. I have a TX5. It’s a great pocket P&S camcorder, and sure, you can get a little video on it. Much better than a “Flip”, but take a close look… that’s highly compressed motion JPEG. It’s chock full of artifacts you won’t see in the Canon’s video.
Also, the Panasonic has weird autofocus seeking behavior. This is due to its origins as a still camera. A video camera may need to trim focus regularly, but it needs to do this in a way that’s not so obvious, or no one will use the autofocus. A still camera needs to find the focus quickly, but just use it for one frame. They have improved this a bit in the latest firmware (do get the upgrade, from the Panasonic site), but I still find it dicey compared to real video.
So on to your questions:
1. Use 1080/24p. It is not even slightly overkill “for what the human eye sees anyhow”. The human eye has 6 million color sensitive photo receptors (cones) and 120 million luma sensitive photo receptors (rods and cones). You can see all benefits of HD, you can see the compression artifacts in HD, you can see the benefits of 4K (four times the data per picture as HD), all of that. It just depends on what you’re using to view it. The 15″ TV in my kitchen will not do justice to 1080p HD.. the 71″ TV in my media room will.
2. Is 720/24p good enough for video on a 42″ TV? Well, it’s better than 480/24p… and there have been a number of excellent films shot on 480/24p. Like “28 Days”. Many others. There are plenty of bad films shot on 35mm, too. For full visual acuity on a 42″ TV at 1080p, the average person should sit about 5.5 feet (there are standards from SMPTE and THX about this, based on the viewing angle, too). At around 15 feet, you’re at the maximum distance to resolve 720p. So basically, if you’re closer than 15ft, you’ll get some benefit from 1080p. Unless you have lousy vision.
3. WMV at 4.8Mb/s for 720/24p? Well, sure, that’ll work. I made my own WMV/HD discs for some years (before Blu-Ray), and generally went to around 6-8Mb/s for 720/60i (cut down from 1080/60i). Obviously, the image improves with bitrate. You can’t make any blanket statements.. 3Mb/s (the standard rate for 720p DivX-HD) may look good on slow moving video, but fail big on sports video. Content matters.
4. Wasting time and space? Nonsense! You should always shoot as high as you might ever need. Storage is cheap (says the guy with 3TB in the PC, 640GB in the laptop, and 8TB of external drive storage), reshooting and regrets are not. I have entered web contests for video (even won one.. look up hoagiefest.com) and kept it 1080i or 1080p all the way to the point I crank out that cheesy 480×360 video for upload. I can always render a better version (which I actually did.. “hazydave” channel on YouTube)… but if I shot in lower resolution, I can’t. That doesn’t mean you need to shoot a film in 1080/60p or forget about it. But even considering deliver in 720/24p, I would shoot and master at 1080/24p. Of course, I’m not trying to squeeze this onto a DVD… I’d made a Blu-Ray, then downconvert to a real DVD-Video for the Blu-laser-challenged among us.
5. 1990x180x12? Someone’s confused… whatever you’re using (Windows?) to view the properties may not be well versed in the ways of AVCHD. The MOV stuff (MJPEG in a QuickTime wrapper) is much more well established (eg, it’s old fashioned).
6. You want to speed up “import and editing process” with smaller clips. Well, first of all, if you’re editing in Vegas, there’s no import time. You mean, copy-from-the-camera time? Is your film that unimportant that this is a big deal? I shoot 2-3 of my daughter’s soccer games a week, in 1080/60p, and think transfers from a flash-based camera are The Bomb. You get that way, after 20 years of tape 🙂
As for editing, yeah, AVCHD is slow. AVCHD at 720/24p is still slow. Two ways to go here. One is to use an intermediate CODEC. I use CineForm. While it’s true a short video I’m doing (soccer highlights from 2008) is currently occupying 462GB of Hard drive with all that Cineform, it’s fast editing. I mean, like, wiz though the video with your jog-shuttle-wheel fast. No waiting. It’s like editing DV, only in HD. MPEG-2 is too slow for more than casual editing, AVCHD editing is just self-flagellation.
The alternative: use a proxy. Go buy “Gearshift” for Vegas. You can edit in SD, nice and fast (but ugly on that second 1200p monitor, compared to the full HD). Switch to HD when you want to see HD. There are other options, but proxy editing is the other path to sanity.
The HF11 is a dandy camera, plenty of prosumer appeal in there. And these have evolved fast… my “Pro” Sony from some years back was pretty much matched by the Canon HV10/HV20 only a few years later, at least in image quality. And the HV20 added 24p! Now I have this frickin’ $400 Sanyo, and it’s even at least in the same quality ballpark, and offers 1080/60p and 30p modes (and some others). And it’s dang near pocket sized. Your camera is not the problem.
But your sound might be. If you’re shooing a film to be watched by actual humans, don’t forget that they have ears. The built-in mics on every camcorder ever made suck. Use an external mic or two, or a field recorder. Or a PC. Or all of the above. Pristine 1080/24p video, with perfect lighting and editing and everything else you can apply is still unwatchable is the audio sucks.
-Dave
Dave Haynie
September 29, 2009 at 2:14 pmWatch the Main Concept CODEC.. most of the presets there are intended for devices, like iPods, not something similar to Blu-Ray in quality. Perhaps you can set up a higher quality output (I’ve actually been messing around with this), but not without a much higher bitrate setting.
You really don’t want to be editing MP4/AVC anymore than you can help it. While obviously that a problem to be solved with an MP4 camcorder, rendering out to MP4 should be considered a delivery format only, not a thing for re-editing. AVC is very CPU intensive, moreso than any other format at least currently in common use. As an example… 1080/60p video from my Sanyo VPC-FH1 (twice the usual amount of information) takes about 65-75% of my Q9550’s CPU (eg, all four cores) just to play back in full resolution and full 60fps speed. It’s much better with GPU-accelerate playback, but you need a player that does this.
Now, you can go faster, but the Q9550 is still a fairly respectable CPU. Now imagine the resources you’re spending trying to edit that, particularly since Vegas, like most other NLEs, seems to use only the one CPU for rendering during edits, and no GPU acceleration. This is the problem with AVCHD and other MP4 editing today.
WMV (the latest version of which follows the open VC-1 standard) is hardly lossless. It’s not quite as sophisticated as AVC, but it has a family resemblance… some of the same people were involved in both. WMV was designed to require fewer resources, particularly on playback, so yeah, on your relatively slow machine, it should play back better. Microsoft also set their original WMV/HD standard to use 720/30p video… easier to fit on a DVD, easier to play back on PCs and devices that couldn’t handle AVC just yet.
Nothing wrong with WMV. If your main distribution target is PCs rather than DVD/BD players, you can technically create a WMV/HD DVD that’ll play automatically on a Windows PC when inserted, complete with menus and everything. Quality is not Blu-Ray level, but hey, you’re watching on a PC, so you’re not looking for that, usually, anyway. Authoring is a bear.. this was never successful enough to spawn lots of authoring tools. Before BD, anyway, I used to hack these by hand… HTML and JavaScript, you see..
-Dave
Alan Andrews
September 29, 2009 at 5:50 pmFolks thanks for these useful responses.
My Camera is actually a Vixia HF20, I think I was dreaming on the 11 🙂 Now worries its still a good camera.
Well I plan to build a Quad PC in the near future, this I am sure will improve things alone. And yes I will probably stick with 180 – 24p. I am staying 32 bit O.S. / 4Gb Ram because of other software besides vegas.
I actually use Cakewalk Sonar for additional audio but plan to get the Zoom H4 as a more portable recording medium. Though I do use Cakewalk for studio recording music etc.
You are right audio sucks from most cams especially in wind.
I’ll look at the TX5 upgrade also.
Being in my infancy with the video recording I obviously want to spend frugally on equipment, but measuring time wasted versus time saved, I understand its a combination of good planning, recording etc a reliable editing system PLUS investment.
I am meeting with a guy who uses Final Cut on a MAC but I sense that just opens the wallet further than I want to. I do have faith in Vegas once I trim the time wasting.
Seems you folks who have dealt with tape etc over the years see the digital editing as a luxury where speed is concerned so I understand that I will still need to have rendering patience.
But can someone please explain cineform more for me in laymans terms.
By principle, starting high allows me to finish high or low as far as whatever output I choose to renderBasic how to ..
In other words for exmaple:
I have my MTS files from the camera, I now want to edit my movie clips into production. Should I convert them first? To cineform? Not sure what is meant I am still wrapping my head around codecs intermediate codecs, my grandmothers kodaks bla bla .. I thought about neoscene?I set my vegas project to the highest (HD 1080-24p(1920 x 1080) But seeing as MTS are VERY compressed maybe I should batch convert all my clips to something more editable beforehand? If so I need to do without loss nor audio being out of synch. Some of my shots still use the camera audio cos it sounds fine or because the sound wave is my time synch if I use dual camera so I need to convert without any slip.
So the question again:
Should I batch convert my MTS files first for editing efficiency, and if so how (what do I use? Neoscene?) so that it produces NO loss NO audio slip.I thank ALL you ladies and gents who have offered great advice once again.
Cheers
Alan
