Activity › Forums › Apple Final Cut Pro Legacy › Is G-tech as good as CalDigit?
  • Is G-tech as good as CalDigit?
    Posted by Bill Thomas on April 14, 2010 at 11:56 pm
    Hi All,
    I’ve been using my $2500 2TB Caldigit for the past 2 years with no issues. But I keep seeing G-tech drives for a fraction of that cost. In particular:
    https://www.videoguys.com/Item/G-Tech+G-RAID+4TB+(4th+Generation)/0303034302432574.aspx
    It seems to have similar specs and supposed to be fine for DVC Pro-HD (which is what I edit in). I’m curious if anyone has used one of these extensively for their Final Cut system with no problems (mechanical, throughput, etc). $500 is sure better than $2000 at this point!
    My system is a MacPro with 8 core running OSX 10.5.4 and 8GB ram. FCP is 6.0.2
    Thanks all…
    Bill
    Cade Muhlig replied 16 years, 5 months ago 8 Members · 13 Replies
  • 13 Replies
  • Alan Okey
    April 15, 2010 at 12:08 am
    I don\’t trust them – they\’re RAID-0. If one of the drives In it fails, you lose everything.
    One of my clients had a lower capacity model and he got hosed when the G-RAID stopped working. He had to pay a fortune for data retrieval.
    What CalDigit RAID do you own? If it\’s RAID-5, then there\’s no comparison. You\’d be comparing a protected RAID to Russian roulette.
  • David Roth weiss
    April 15, 2010 at 12:11 am
    Bill,
    You’re comparing two very different products. The G-Tech device you pointed to is a fully enclosed, pre-manufactured hard drive with two completely unknown 2Tb drives inside, which cannot be replaced or swapped-out or anything, and it uses software raid, which is not as fast or as dependable as CalDigit’s 100% hardware raid products.
    If one of the drives in the G-Tech enclosure goes “Klapooey,” the entire enclosure is NG, you can’t simply replace one or both drives. And, while I have no idea which CalDigit model you have, I do know it has replaceable drives. And, if you want you could even update all of them to larger drives, or buy a second set of drives, etc, etc, etc.
    So, the bottom line is, don’t spend more than you want or buy more than you need, but know that when you’re spending your money on CalDigit you’re getting more than just two drives sealed in a disposable enclosure.
    Doe s that make sense?
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    EPK Colorist – UP IN THE AIR – nominated for six academy awards
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Shane Ross
    April 15, 2010 at 1:41 am
    I used to trust them. But then many dealers were getting drives returned that didn’t work right out of the box. And not a small number. 8 out of 15 would come back.
    Shane
  • Tom Brooks
    April 15, 2010 at 1:49 am
    Caldigit has great prices on their site right now. I have a VR 2TB unit that I bought to store some critical client assets on. I’m using it in RAID-1 for protection. It’s solid as a rock. For reasons David mentions, it’s a different product, way above the specific G-Raid in the link. Caldigit’s philosophy on RAID and on customer service makes sense.
    That said, I’ve put countless hours on two G-RAID drives, too. Their fans make noise on cool winter mornings. I sent one in for repair about a year ago, which was done for free just past the 3-year warranty. The other one groans and wheezes on startup (again with the fan) but keeps going.
    Right now, the CalDigit VR is a great buy. Well worth an extra $99.
  • Russell Lasson
    April 15, 2010 at 5:42 am
    Both companies are good.
    [Bill Thomas] “It seems to have similar specs and supposed to be fine for DVC Pro-HD (which is what I edit in).”
    You could edit DVCPROHD on a single drive without issue.
    -Russ
    Russell Lasson
    Colorist/Digital Cinema Specialist
    Color Mill
    Salt Lake City, UT
    http://www.colormill.net
  • Colin Mcquillan
    April 15, 2010 at 7:42 am
    It’s comparing oranges to apples.
    The g-speed es would be their version of the product you have.
    I own two g-speed es units and a 2tb g-raid. I haven’t had any issues with any of them. Also, Hitachi owns GTech,,, so it really isn’t any mystery what kind of drives you are getting inside.
    Colin McQuillan
    Vancouver, B.C.
    “Live, love, laugh and be happy.”
  • Bill Thomas
    April 15, 2010 at 2:54 pm
    Thanks for all the info, guys!!
    For the record, my CalDigit is an S2VR 2.5TB with 5 Hitachi drives. The Raid is set at “Performance” which I’m guessing is Raid 0. (Can anyone confirm?).
    As far as losing data, the tech at CalDigit said if 1 drive goes, I lose everything, so I assume it’s Raid 0.
    The only issue I’ve had has been the external drives unmounting at random – but I think that’s a Leopard issue, not CalDigit. I have then had to use Diskwarrior to redo the directories.
    Bill
  • David Roth weiss
    April 15, 2010 at 4:37 pm
    [Bill Thomas] “As far as losing data, the tech at CalDigit said if 1 drive goes, I lose everything, so I assume it’s Raid 0. “
    Yes, that would be RAID 0. You could change that to RAID 5.
    [Bill Thomas] “The only issue I’ve had has been the external drives unmounting at random – but I think that’s a Leopard issue, not CalDigit. I have then had to use Diskwarrior to redo the directories.”
    Have you spoken with CalDigit about this?
    DiskWarrior should be considered routine maintenance, not an emergency measure only. If you run it once a month you might find you’ll never have emergencies.
    David Roth Weiss
    Los Angeles
  • Alan Okey
    April 15, 2010 at 4:46 pm
    David,
    The S2VR is a legacy CalDigit product that only does RAID-0, RAID-1 or JBOD. There’s no onboard RAID-5 controller.
  • David Roth weiss
    April 15, 2010 at 4:55 pm
    [Alan Okey] “The S2VR is a legacy CalDigit product that only does RAID-0, RAID-1 or JBOD. There’s no onboard RAID-5 controller. “
    Thanks for clarifying that Alan.
    David Roth Weiss
    Los Angeles
