Activity Forums Apple Final Cut Pro Legacy Is FCP Scriptable?
  • Is FCP Scriptable?
    Posted by Justin Ficklin on August 18, 2007 at 10:39 pm
    Is there any way to record a set of actions in FCP? As an assistant editor, simple, repetitive tasks are a daily ritual and can be very time consuming. I’d love some way of scripting some of these actions like I’m able to do in Photoshop. Any information would be appreciated. Thanks guys.
    -Justin
    Francois Stark replied 19 years, 1 month ago 4 Members · 4 Replies
  • Jerry Hofmann
    August 19, 2007 at 2:12 pm
    FCP isn’t scriptable… but maybe if you post what these repetitive tasks are, we can come up with a better/faster workflow.
    Jerry
  • Andy Mees
    August 19, 2007 at 3:02 pm
    its not especially scriptable, although you can trigger import and export of XML’s using apple events
    https://developer.apple.com/samplecode/MovieAssembler/index.html
    you can also use Apple’s UI scripting to take some control
    https://www.apple.com/applescript/uiscripting/
    or you could look at something like xmedit’s Traffic app
    https://www.xmedit.com/
  • Justin Ficklin
    August 20, 2007 at 5:37 am
    Thanks for your suggestions …
    As an example, some of the duties include preparing/tweaking projects for editors with a set of detailed guidelines that are always followed in a certain order. Simple yet time consuming.
    These guidelines include:
    -Changing sequence settings
    -Importing media into certain bins and the timeline
    -Rendering out sequences
    -Adjusting timings
    -Media management
    -Saving a new version of the project
    ..The Traffic app seems vaguely helpful, but I’m not sure it’s as in depth as I’d like it to be. There’s no way of apple scripting any of this is there?
  • Francois Stark
    August 20, 2007 at 7:07 am
    I use quickeys to do repetitive tasks in FCP. Helps a lot.
    https://www.cesoft.com/products/quickeys.html
