Activity › Forums › Avid Media Composer › is drag and drop export broken?
Posted by Hector Berrebi on July 27, 2011 at 2:14 pmno drag and drop export in recent versions?
haven’t used it in a while, and today i tried but it wouldn’t work
i’m on MC 5.0.3, on a mac
tried on both AMA and transcoded media
anyone else noticed this?
hector
Hector Berrebi
prePost ConsultingScott Cumbo replied 15 years, 1 month ago 4 Members · 4 Replies -
Nick Hrycyk
July 28, 2011 at 10:53 amBasically a batch export.
Set your Export settings to what you want, making sure they are the active settings. Hilite all clips/sequences you want to export in a bin, drag them to a folder on your desktop and they start exporting. The benefit to this was not needing to hit ‘enter’ after each file was exported, the way you did if you just right click on a bunch of clips/sequences in a bin and chose ‘export’.
Could this be a Mac/PC thing, Just recently switched from PC MCv5.03 where I’m pretty sure it worked to a Mac MCv5.03 and it didn’t work. However I did notice that I didn’t have to ‘enter’ after each sequence was done.Nick Hrycyk
Digital Image Studios -
Hector Berrebi
July 28, 2011 at 12:20 pm[Nick Hrycyk] “Could this be a Mac/PC thing, Just recently switched from PC MCv5.03 where I’m pretty sure it worked”
Maybe… I switch between Mac and PC quite often, But I’m almost sure I used it on Mac …almost 🙂
When you’re on PC try choosing a bunch of clips/sequences and instead of right click and export, pick export from the file menu. I think this solves the pressing enter you mentioned.
Hector Berrebi
prePost Consulting -
Scott Cumbo
July 28, 2011 at 3:31 pmOn PC you don’t need to hit enter, just highlight all your clips/sequences, right click and choose export
Scott Cumbo
Editor
Broadway Video, NYC
