Is boom and lav always the way to go? Audio Commentary
“Boom and Lav”
I was recently surprised to hear someone say that an Audio Tutorial DVD was suggesting that you boom and lav one person as an insurance policy. Maybe something got lost in the communication. Let’s discuss.
I understand being nervous about audio and appreciate that you want to cover your bases. When that happens, do you have a dedicated person doing audio or are you multi-tasking? Are you listening to the audio as it’s shot? If you’re not listening to the audio critically, you’re doing it wrong. If there’s a problem, you’ll hear it.
When I’m hired to do audio for a shoot, I’ll usually try each to hear which one works best, unless it’s obvious which one works best. For most indoor, sitdown interviews, for example, I’ll boom to both channels because my Schoeps cmc641 boom mic sounds a lot better than any lav. I’m more concerned that there’ll be dropout on the tape than that using a proper boom mic will cause a problem.
Lavs can be problematic; hiding them, placing them so you don’t get clothing noise, invading the personal space of the talent. You need to know how to do all of these properly to make the lav experience a good one. If it’s OK to see the lav, then life gets a lot easier, but I’ve found that more producers these days prefer not seeing the lav, if possible. It takes a combination of more time, better gear and more skill to do that.
We were outside on a one-shot last month. My first thought was that a 416 would be fine. Due to the amount of low (and not so low) level background noise; airplanes, helicopters, lawn mowers, leaf blowers, beep-beep backup vehicles, the omni lav isolated the voice better than the 416 because was closer to the mouth and the body was blocking some of the omni characteristics. (Remember, an interference tube mic is a lot more omni at mid and low frequencies.)
I didn’t try a boomed hyper. Didn’t have time. It would have been tighter than the 416. Maybe better than the lav, but the outdoor noise covered up the selfnoise of the lav just fine.
There is also the real possibility that someone will combine the tracks in post to the detriment of the sound. If you are a 1-person operation, that’s less likely, of course.
The “combining boom and lav” approach presents some interesting possibilities. Sure, you do need to check to hear how much time realignment is needed, but I have to open a different thought process here. I also record and mix music for a living. I’m pretty familiar with blending mics and sources.
I didn’t start with great gear. I built it up over time. I found that as I got better mics and preamps, my job as mixer got a lot easier because the better gear had fewer nasty peaks, edges, polar and phase issues. I think a lot of people try to minimize mic and preamp problems (as I did) by making mixing decisions that are as much about minimizing artifacts as mixing. So if someone’s gear is entry or mid level, they can EQ and mix all day and not get sound as good as they could of they had better tools in the first place.
I was struck recently while listening (and watching) the latest “Pirates of the Carribean” movie. As I listened to the interior dialog, my ears perked up. Get the movie on DVD. Listen to the dialog with a good set of headphones. As it turned out, I knew someone who knew the guy who did the location sound for the movie. What you hear is one Schoeps cmc641 boom mic. Not to say it’s always the right decision, but don’t let platitudes (boom and lav) compromise your audio. Boom and lav has it’s place, but if you have a good audio person, let them make the decision, or at least discuss it with them.
Enjoy the holiday weekend. Hey, maybe break out the audio gear and play with lavs, hyoers and booms with good headphones while you shoot the backyard cookout.
Regards,
Ty Ford
Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
Watch Ty play guitar
