Activity Forums Adobe Premiere Pro Is avi-format hard to import?
  • Is avi-format hard to import?
    Posted by Mikael Ahlin on February 17, 2008 at 7:52 pm
    Hi.
    When I import mpeg-files to Premiere they appear faster, much faster then avi-files. I tried to import several avi-files with sizes of between 200 and 340 Mb, but after 1 hour waiting I canseled importing dialog because it seemed to be hung up. Mpeg-files of even bigger sizes were easy to import. Why? Or how to solve this problem?
    Thank you.
    Vincent Rosati replied 18 years, 7 months ago 2 Members · 1 Reply
  • Vincent Rosati
    February 18, 2008 at 1:52 am
    AVI is basically a container. It can hold all sorts of audio and video codecs. It’s likely the codecs that are the issue.
    I recommend you try using Gspot to identify the codecs of any given movie file…
    https://www.headbands.com/gspot/
    I always default to decompressing movie files if there are any import issues. I use AVS Video Converter…
    https://www.avsmedia.com/
    Vince
