Activity › Forums › Blackmagic Design › Is analog component useless on Decklink?
  • Is analog component useless on Decklink?
    Posted by Peter Gruden on January 21, 2007 at 4:53 pm
    I can’t get proper gain on analog component input on Decklink SP. Even when I set Processing gain to maximum (1.76) the whites are not what they should be.
    I wonder if I’d have the same problem capturing HD analog with HD Extreme. If so a digital only card with a quality external converter should do the trick.
    Component output on SP seems fine. I compared it with another component converter and I could find no difference.
    Peter
    Peter Gruden replied 19 years, 8 months ago 3 Members · 3 Replies
  • Peteros
    January 21, 2007 at 11:59 pm
    What’s your source? I have been using HD component in on my Extreme card with no probs…
  • Kristian Lam
    January 22, 2007 at 6:05 am
    Hi Peter,
    We need to know if this is happening only with one source or across multiple sources. Some variances may be present when capturing analog video which is why we have the pro-amps but if you find that you have this is happening across multiple VTRs, then there may be a problem with the card’s input.
    regards
    Kristian Lam
    Blackmagic Design
  • Peter Gruden
    January 22, 2007 at 9:24 am
    I did the test with two sources, Beta SP and DAC10 DV to component video converter. The result is the same on both. When I adjust gain to maximum the whites are still noticeable lower compared to the source.
    Peter
