Activity Forums Storage & Archiving Is an this G-RAID External Hard Drive Array overkill?
  • Is an this G-RAID External Hard Drive Array overkill?
    Posted by Kristyn Davis on September 25, 2012 at 5:57 pm
    Hi everyone,
    I’m doing a docu-series with some buddies of mine. Each episode will be 30-min long and shot in HD. I’m going to get a new hard drive for the series, so I’m looking at the G-Technology 4 TB G-Drive Professional External Hard Drive and the G-Technology 4TB G-RAID External Hard Drive Array.
    I’m going to be using someone else’s computer for this project so I can’t change any of their configuration, or buy anything that I can’t take with me when I leave. Would the second drive be overkill or even work properly on a computer with no RAID config whatsoever?
    Thanks for your help!
    Rainer Wirth replied 13 years, 10 months ago 2 Members · 1 Reply
  • Rainer Wirth
    November 13, 2012 at 3:45 pm
    First of all:
    G-Raid raid level5
    get the best hd’s available (Hitachi Ultrastars to me)
    test it on your working environment.
    Take one spare disc with you! (for the G-Raid)
    The second back up you can do on a normal USB Harddisc. If you have huge data go with your normal Harddisc over FW (need a FW Port)
    Good luck
    Rainer
