Activity Forums Adobe After Effects Iron Man HUD – Scale up 3D scene to match 2D background plate
  • Iron Man HUD – Scale up 3D scene to match 2D background plate
    Posted by Mike Douglas on July 10, 2014 at 12:30 am
    Hi there, I have a 3D scene that I’ve created using the 3D Camera Tracker. It was tracked from a video clip that had a locked off camera with a guy moving his head around. I’m doing something very much like the Iron Man helmet HUD, and I want the HUD elements to move around when he moves his head.
    The 3D Tracker seemed to be the best way to get this tracked, but it results in a camera that moves around and static elements, which is totally backwards but it’s generally working. If someone has a better solution, I’m open to that! That’s not my question, though.
    Assuming I’m going with this approach, I need to scale up my original footage about 250% so that it’s cropped correctly, but if I scale it up or move it around, it no longer matches the 3D scene.
    I don’t want to work with everything smaller than needed, precomp it and scale up the precomp – even if I continuously rasterize all of the elements that will just turn into a massive pain with blending modes.
    Any ideas on how to scale up both the 2D background plate AND the 3D scene? Thanks!
    Mike Douglas replied 11 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
