Activity Forums VEGAS Pro IRE levels and overshoot – Hi8 transfer (DV to DVD)
  • IRE levels and overshoot – Hi8 transfer (DV to DVD)
    Posted by Jacob Hobbs on August 7, 2007 at 6:06 pm
    I am capturing Hi8 tapes using a Canopus ADVC-300 to DV format, and then to DVD. I would like to know if overshoot is allowed in the digital domain on DV and DVD?
    My Workflow
    The Canopus ADVC is set for 7.5 IRE. I have the Vegas scopes set for Studio RGB (16-235). The Canopus ADVC has an auto-gain feature, but when I turn it on, it always boosts incoming whites to (235-255).
    The Problem
    The problem is, if I manually set gain on the ADVC, so the range is (16-235), the digital transfer turns out much darker than the original analog recording.
    I believe the consumer camcorder used the super-white range for actual video content above 235. So for a consumer video transfer, should I leave Auto-Gain on, and allow super-white when transfered to DV and DVD?
    The ADVC software also has options for white peak adjust and White step. Should these be used instead of manually adjusting gain?
    Jacob Hobbs replied 19 years, 1 month ago 2 Members · 3 Replies
  • Douglas Spotted eagle
    August 7, 2007 at 8:16 pm
    I would recommend setting the white peak manually if the software allows you to do so. Another option, if you don’t have clipping occurring in the range, is to bring in the footage with the superwhite, and repair it/set to correct levels in post.
    Douglas Spotted Eagle
    VASST
    Aerial Camera
  • Jacob Hobbs
    August 7, 2007 at 10:57 pm
    My DV captures have a small black border on left and right side. The broadcast colors filter is reading this area as black. So it adjusts everything according to this area, which is incorrect. All detail is lost in the blacks. Is there a way to mask this area or change the border to IRE 7.5, before applying the broadcast colors effect?
  • Jacob Hobbs
    August 7, 2007 at 11:01 pm
    Oops…nevermind. I didn’t have 7.5 IRE setup selected in broadcast colors effect. Thank you for your previous response.
