Activity › Forums › Square Box CatDV › IPTC metadata
IPTC metadata
Posted by Pierre Valliere on October 15, 2013 at 3:59 pmI’m trying to see in CatDV some ITPC metadata that i’ve enter in others software (Adobe Bridge, XnView, ACD See), but it’s not working except for the fields Description, that is the fields “Information” in CatDV… Can anyone help me?
I’m on CatDV v9 on a mac.
Stuart Peck replied 12 years, 11 months ago 4 Members · 8 Replies -
Bryson Jones
October 15, 2013 at 4:50 pmAre you using a server version or stand alone? And have you enabled the metadata columns?
If it’s standalone then you need to make sure “ENable Metadata columns” is checked in the “Metadata Columns” preferences area.
On server connected versions “Metadata columns” is under the “Field Definitions” preference pane.
bryson
bryson “at” northshoreautomation.com
Pierre Valliere
October 15, 2013 at 8:16 pmI’m using Server version, and yes, “Metadata columns” is check. Under witch field i’m suppose to see IPTC ? I’ve try a lot and did’nt find.
Bryson Jones
October 15, 2013 at 9:59 pmIf you have the “other” tab exposed in the Details Panels, it should be there.
If not, look at your prefs under Details Panel and you can enable it there.
bryson
Dougal Matthews
October 16, 2013 at 10:26 amhi Pierre
you might want to create a new view to show your iptc data there’s a good guide on the squarebox website here
https://www.squarebox.com/tutorial-customising-metadata-display/
explaining how to do this
good luck Dougal
Improvise Adapt and Overcome
but remember: out of good , quick and cheap
you can only pick TWO …
Pierre Valliere
October 16, 2013 at 8:53 pmThanks Bryson, it’s there, half of the fields I’m looking for are there. IF’ve find the Creator (Artist in CatDV), Description (Information in CatDV), and Copyright fields but did’nt find any matching fields in CatDV for Source, Keyword and Location (in Bridge, XnView and ACD See)
Stuart Peck
October 22, 2013 at 1:09 pmThere are several missing IPTC fields, and what you do see won’t all be as you’d expect to see IPTC data. Their names will be prefixed with IPTC4
Sublocation is a metadata field, source is missing and keywords are not IPTC but also do not show in the default view.
In your tabs, create a new tab called IPTC and when choosing your fields in which to add, hit the I key when a field is selected. Scroll down to see the IPTC fields available. Add them to your tab and save.
These are the present IPTC4 fields in CDV. You’ll have to edit them in order to have them display something meaningful.
This will only work for embedded files, i.e. if you work with sidecar XMP (RAW Workflow) these files will appear as a separate file in CDV and will not relate to its image file. Hence, would recommend using Lightroom, Photo mechanic, Bridge, Capture one etc
Stuart Peck
Media consultanthttps://stuartpeckphotography.com
https://www.sickmac.co.uk -
Stuart Peck
October 24, 2013 at 10:19 amNo problem Pierre
Glad you got it sorted
Stuart Peck
