Activity › Forums › Apple Final Cut Pro Legacy › ipad conversion
  • ipad conversion
    Posted by Diane Collins on June 15, 2010 at 3:51 pm
    I am new to FCP and am having lots of trouble – hoping you can help me out.
    I am making a video in FCP with still images and I am trying to export this movie for the ipad.
    When I export using h.264, the text in the still images looks very blurry and the images are washed out.
    I’ve seen lots of posts on this issue, but haven’t found an answer that works. The text was done in photoshop and placed over the image, and then imported in FCP.
    I tried exporting the FCP file with the Animation codec and it looks good when I play it in quicktime.
    But…then the file doesn’t work on the ipad.
    Any help would be greatly appreciated.
    Diane Collins replied 16 years, 3 months ago 4 Members · 23 Replies
  • 23 Replies
  • Jeremy Garchow
    June 15, 2010 at 4:18 pm
    in HD, iPad has to be 720p30 (or 720p24) h264 and the audio needs to be 160kbps.
    What format/frame rate is your timeline?
  • Diane Collins
    June 15, 2010 at 4:24 pm
    Hi Jeremy,
    Thanks for your reply.
    When I export for h.264 at the correct frame rate, the video plays on the ipad.
    The problem is that the text in my images look blurry and the images themselves look really faded and washed out. Is there a way to export to h.264 but keep the same image quality?
    Does this make sense? Thanks!
  • Jeremy Garchow
    June 15, 2010 at 4:28 pm
    What format and frame rate is your timeline?
    This will help answer the ultimate question.
    I should add that audio should be AAC @ 160kbps, stereo.
  • Diane Collins
    June 15, 2010 at 4:35 pm
    Sorry, but I am VERY new to FCP. I went to the Format window (from Edit). Not sure if this is where I’m supposed to check, but it says the Vid Rate is 29.97.
    Is this what you’re looking for?
  • Walter Biscardi
    June 15, 2010 at 4:52 pm
    We just use the stock iPhone HD presets in Compressor here and everything looks surprisingly good. We’ve made files from 720p/59.94 and 1080i / 29.97 timelines.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author, Chef.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” featuring Sigourney Weaver coming soon.
    Blog Twitter Facebook
  • Diane Collins
    June 15, 2010 at 4:54 pm
    I am using FCP 5 – would that work in this version?
    That would be awesome if so. I’ve been trying to figure this out for days!!!
    Thanks for all of you help.
  • Jeremy Garchow
    Actually, AppleTV would be the closer choice.
    Jeremy
  • Jeremy Garchow
    June 15, 2010 at 4:57 pm
    With your sequence selected, hit command-zero to bring up the sequence settings.
    Jeremy
  • Diane Collins
    June 15, 2010 at 5:01 pm
    frame size 720 x 480 aspect ratio NTSC DV (3:2)
    compressor DV/DVCPRO – NTSC
    I’m going to try to export with compressor now..
  • Diane Collins
    June 15, 2010 at 5:04 pm
    OK, I got ahead of myself. I don’t know how to use compressor.
    Do I export the file in FCP and then bring it into compressor?
Page 1 of 3
