Activity › Forums › AJA Video Systems › ioHD vs. KiPro
Joseph Robinson
December 11, 2009 at 6:18 amBob your post is hilarious. Sure appreciate all the input on these. We are brand new to video and are simply learning and hoping to land a “real” video guy to guide us. We shoot 80% of our video in an auditorium setting with two cameras.
Two – Sony PMW-EX1 XD Cams
MacBook Pro – 2.4 GHz Intel Core 2 Duo
2TB – CalDigit VR – FASTA-1ex SATA Express Card
Final Cut Pro 6.0.6Our work flow has been to shoot while hot-swapping SxS cards. During shoots we insert full cards into the Mack and dump them via Firewire 800 to the external HD
Once the shoot is done we plug the External HD into the express slot and do all post production in FCP. Post production was a killer at our last conference.
This is the solution I’m thinking in my uneducated skull of mush
1. Shoot both cameras and output HDSDI (also record SxS as a backup)
2. Video switcher to
3a. AJA KiPro (or ioHD)
3b. AJA ioHD thru FW800 thru MBP thru FCP to External HDThree Questions
1. Are either of these intelligent work flows?
2. Based on what we’re shooting, ioHD or KiPro?
3. Could sure use a recommendation on a simple, inexpensive ($4k) HD video switch. Simply need to switch between two video signals. An adjustable fade during the switch would be nice. The ability to expand to 4 video inputs would be great as well.Any input would be greatly appreciated.
Jeremy Garchow
December 11, 2009 at 5:58 pmWHy not just get two KiPros and save yourself the hassle of the switch? You can ISO the two cameras and edit later.
Jeremy
Joseph Robinson
December 11, 2009 at 7:32 pmCorrect me if I’m wrong but I want to switch between cameras live. The resulting stream from the switcher mixed with the audio will give me a single file I can clean up in FCP and drag into DVD Studio Pro. This saves me manually cutting from cam1 to cam2 in post production.
Post production is cool when we’re filming dramatic presentations, but when it’s simply a conference speaker, I’d like to switch live and be ready to quickly slap it on a DVD.
Does that make sense or am I missing something?
Jeremy Garchow
December 11, 2009 at 8:03 pm[Joseph Robinson] “Does that make sense or am I missing something?”
Makes tons of sense. If that’s the best workflow, then that’s the best workflow. I guess you could always use the SxS as ISOs if you need it.
I didn’t realize it was such a quick turnaround.
Jeremy
Joseph Robinson
December 12, 2009 at 12:49 amSo (back to my original post) I’m wondering, based on my workflow, would you recommend the ioHD or the KiPro?
Again 80% of what we do will be in a controlled environment. We will do some shots occasionally in the field. We have Anton Bauer adapters for all our equipment. I assume we can get something for the ioHD or KiPro. I’m just wondering which unit would probably be best for us.
Any suggestions are appreciated.
Gary Adcock
December 12, 2009 at 3:39 pm[Joseph Robinson] “So (back to my original post) I’m wondering, based on my workflow, would you recommend the ioHD or the KiPro? “
That’s your decision, IoHD offers more options but requires being tethered to a laptop.
“We have Anton Bauer adapters for all our equipment. I assume we can get something for the ioHD or KiPro”
For the KiPro YES,
With the IoHD, a power inverter would be needed as it only runs on AC power.gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, ILhttps://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
