Io switching to RGB mode in fcp
I am having a weird issue with the Io and Final Cut 5.02.
Last week a client dropped off some footage on svhs. It has been a while since I have dne anything with that, but I was able to capture it w/o any issues.
Today I attemted to capture some more fotage from the same tapes, but when I opened the Log and Capture window, my broadcast monitor went pink, and I could not get a video signal from the VTR.
If I close fcp and launch the Io control panel, it indicates the Io is in component RGB instead of SMPTE/EBU N10.
Switching the settings back to SMPTE corrects the isuue, and I can then view the video footage correctly until I attempt to do so in fcp.
The moment I open the capture window, the Io goes into RGB mode.
I have reinstalled the latest Io drivers and have double checked the firmware – everything is up to date.
I have power cycled everything several times, but nothing solves the problem.
Nothing on my system has changed. Between the time I last captured svhs src, I have been working with DVCPRO src.
And again, I must stress that svhs capture was working last week!
I have tested the cables and switches and everything wrks fine, I have swappe s-vid cables but not joy.
I have also attemtped to try the same test with my Hi8 vtr, but with the same results. The same happens w/composite input on the Io.
As usual, I am up against a deadline and this problem is really causing me grief.
Anyone have any ideas??
TIA,
-k
