Activity › Forums › AJA Video Systems › Io now feeds Kona2 ! (repost from Io forum)
  • Io now feeds Kona2 ! (repost from Io forum)
    Posted by Bill Portune on May 11, 2005 at 12:48 am
    With the help of the new Io control panel, I’m now using my Kona2 for all my work. BetaSP, D9, Digibeta, HDCam, and analog monitoring – all accessable – all the time!
    Thanks AJA, everything is working as advertised!
    Bill Portune
    The Chesapeake Group
    G5 DP 2G, 10.3.8, QT 6.5.2, 1.5GB RAM, FCP 4.5, Io/Kona2, UL4D, Huge U320R
    Walter Biscardi replied 21 years, 4 months ago 6 Members · 6 Replies
  • Walter Biscardi
    May 11, 2005 at 1:24 am
    Hey Bill! Thanks for the great news, that’s very very cool.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Sam
    May 11, 2005 at 2:16 am
    Hi Bill
    Can you please explain how your workflow is setup and what hardware (decks) are you using. I am in a similar boat where I am trying to setup the IO and Kona2 together for the BetaSP work. How are your input/outs configured with both.
    Sam
  • Rich Sims
    May 11, 2005 at 3:26 am
    Hi Bill or anyone with news,
    I have the Kona2 and an IOLA as opposed to the IO. Can I gain the same functionality as IO users?
    Rich
  • John Ladle
    May 11, 2005 at 10:14 am
    rich,
    the IO LA does not have SDI out, so you can use it as you always do for SD, but it cannot pass an SDI signal to the kona 2 for uprez, for example. otherwise you can ingest audio all you want viea firewire…
  • Becky
    May 18, 2005 at 5:55 am
    I’d like to know this configuration information too.
    And what are the limitations of the Kona 2 card that make the IO advantageous?
    Becky
  • Walter Biscardi
    May 18, 2005 at 12:23 pm
    [Becky] “And what are the limitations of the Kona 2 card that make the IO advantageous?”
    There’s no Analog Input on the K2. Analog Ouput on the K2 is limited to Component and unbalanced RCA audio. So if you need any other type of analog I/O, you want to add at least the Io LA to a K2 system.
