Activity › Forums › AJA Video Systems › IO HD with ProRes 422 HQ crashes FCP 6
  • IO HD with ProRes 422 HQ crashes FCP 6
    Posted by Dave Martin on January 30, 2008 at 8:16 pm
    Hi Guys
    It could be because my hard drives striped can only do 200 kbits per second and the files are 240 kbits per second but…Anybody else have this issue? It seems to work well with regular ProRes 422 but not HQ.
    The render is coming out of After Effects CS3…thanks!
    Dave Martin
    – MacPro – MacBook Pro –
    David Zimmern replied 18 years, 5 months ago 4 Members · 12 Replies
  • 12 Replies
  • Jeremy Garchow
    January 30, 2008 at 9:22 pm
    What drive are you using that does 200kbits per second?
  • Dave Martin
    January 30, 2008 at 9:35 pm
    I have three Hitachi Deskstars Striped Raid 0 internal on a MacPro. I’m pretty sure I get 200 kbits per second…
    Dave Martin
  • Jeremy Garchow
    January 30, 2008 at 9:44 pm
    You mean more like 200 MegaBytes per second. Plenty to do ProRes or HQ
    So explain exactly what happens and what format, OS, QT, AJA drivers, version of everything you have ever owned, or more importantly what versions you are currently running.
  • Dave Martin
    January 31, 2008 at 4:27 pm
    Well, the encode goes fine for ProRes 422 HQ out of After Effects and it plays well in Quicktime…but as soon as I drop it in a ProRes 422 HQ Timeline in FCP V 6.0 I get the spinning beachball.
    I have the IO HD firmare 1.1 and Control Panel V 5.0 as well as Quicktime 7.3.1.
    I thought about updating FCP but others have said it breaks more than it fixes…
    Any ideas?
    Thanks…
    Dave Martin
  • Jeremy Garchow
    January 31, 2008 at 4:53 pm
    FCP v6.0.2 is most stable version of FCP6 there is, in my experience anyway. Don’t know if that’s your issue though. I’d start there. Also, there’s an update to AE CS3 to 8.0.2.
    What resolution are you working in?
    Jeremy
  • Dave Martin
    January 31, 2008 at 5:55 pm
    Hi Jeremy
    I guess I’ll try the update (I’ll clone first)
    I’m working in 3500 x 1080 in AE and then stretching down to 1920 x 1080i for FCP
    Thanks…
    Dave Martin
  • Gary Adcock
    January 31, 2008 at 6:07 pm
    [Dave Martin] “I’m working in 3500 x 1080 in AE and then stretching down to 1920 x 1080i for FCP “
    The IoHD does not support video files larger than 1920 pixels wide at this time.
    down convert in AE first.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Dave Martin
    January 31, 2008 at 7:31 pm
    Hi Gary
    Yes…I made it 1920 x 1080 1 PreRes 422 HQ in AE and then tried to import…
    Thanks…
    Dave Martin
  • David Zimmern
    May 1, 2008 at 10:33 pm
    I am running a macbook pro,7200rpm hd,4gig ram,fcp6,aja iohd,sata raid and have tried 800firewire graid.I get a kernal panic when I drop clip onto the timrline.It works fine for capturing.But when I do a time remap or play clip on a timeline” CRASH”.A proApp Tec from Apple told me the system was not tested with an external raid!How do you test an edit system without an external drive?and OK the system.
    thanks, dave Z.
  • Gary Adcock
    May 2, 2008 at 1:22 pm
    [David Zimmern] “.A proApp Tec from Apple told me the system was not tested with an external raid!How do you test an edit system without an external drive?and OK the system”
    an Apple store tech will not know anything about an IoHD so do not waste your time- if it is not sold in the store they will not know what it is or how to trouble shoot.
    Since you did not tell us which OS and software versions start there,
    did you update the Driver and THe IoHD
    Have you called Aja’s Tech support?
    gary adcock
    Studio37
