Activity › Forums › AJA Video Systems › Io HD, ProRes from Digital Betacam and sound longer than video
  • Io HD, ProRes from Digital Betacam and sound longer than video
    Posted by Vladimir Novikov on December 7, 2012 at 10:26 pm
    HI all,
    I need to send the video with visible time code and VI sound overseas for dubbing, and I get a small problem while ingesting the DigiBeta using Io HD.
    I use Mac OS X 10.8.2, last versions of Aja drivers and software and Compressor 4.0.6.
    The Digital Betacam is acquired as ProRes 422HQ SD PAL QuickTime MOV file. When I check the movie properties (Command – J), I see the video track 1:02:30:04 long and four sound tracks 1:02:30:21 long.
    So, the sound tracks are a little bit longer then the video track. I didn’t notice any problem of video/audio sync, but still…
    I’ve used Compressor to produce an h.264 file with visible time code and the file has both streams 1:02:30:04 long.
    Now, when I export the sound using the Export -> Sound to AIFF command, I get two possibilities: one AIFF file with two discrete channels or one AIFF file with a stereo pair. In both cases the file is 1:02:30:04 long, so Quicktime corrects this small difference of duration.
    But if I use the Extract option from the properties view, I get two independent AIFFs each 1:02:30:21 long.
    I presume it’s not a big deal, but still would like to know why it happens.
    Other question, the dubbing guys ask me to send them the files as FLAC. I presume they want to save upload/download time and bandwidth, but I’m afraid another transformation will produce another time shift. FLAC and ALAC are lossless, so AIFF – FLAC – AIFF should in theory produce exactly the same file, but who knows…
    Vladimir Novikov replied 13 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
