Activity Forums AJA Video Systems IO error message
  • IO error message
    Posted by Mike on August 29, 2007 at 11:59 pm
    Ok, I’ve tried everything and still cant figure this out. I have the IO firewire plugged into the back of my mac pro. No other firewire devices are plugged in on the back, just the IO. However, I do have a firewire drive plugged in the front of the computer. I don’t think this would effect the IO since they are different ports…correct?
    I still get the error message:
    “Unable to open the specified Video Output device.
    It may be in use by another application, incorrectly connected or may be conflicting with a sound input device”
    I have a Kona 3 card installed as well.
    What’s going on? Any thoughts?
    Mike
    Jeremy Garchow replied 19 years ago 2 Members · 1 Reply
  • Jeremy Garchow
    August 30, 2007 at 12:13 am
    Different side of the computer, same ports. If you need another firewire port on your computer while using an io, it’s time to get a PCI card.
    Jeremy
