Activity Forums AJA Video Systems IO can’t capture clips over 20-30 min.
  • IO can’t capture clips over 20-30 min.
    Posted by Morten Raarup on September 19, 2006 at 4:48 pm
    I have a problem whit my IO. I can’t capture a clip over 20-30 min. It do not matter if I am loading in DV, DV50 og uncompressed 10 bit. It stops every time. I am using a “HUGE” drive, and when test the speed – it’s 200 M/s. I have tryed to put a decklink card from an other system in my G5, and then I don’t get any drop outs – even when i capture 90 min. in uncompressed 10 bit.
    I have contacted AJA support, but the first time the replyed that it was harddrive problem. When I replyed that it worked if I use a decklink card, they did not replyed. The next time I contaced AJA support they asked if there was any other devices conneced to the firewireport. When I told them that the IO was the only device on the firewire port – they did not respond.
    Is the any thing to do, or must I join the club of “Things to do with my IO when I’m not using it?”
    Morten Raarup
    On Off Line Postproduction
    Copenhagen, Denmark
    Morten Raarup
    Copenhagen, Denmark
    Ed Dooley replied 20 years ago 4 Members · 6 Replies
  • Tony
    September 20, 2006 at 4:58 pm
    From you test in which you swapped a decklink into your mac I assume you have decklink driver installed also in addition to the AJA drivers?
    Well that sounds like a possible user configuration error.
    Clear out the BM drivers and if needed do a clean install of the AJA drivers, FCP and the Huge drivers if needed.
    Tony Salgado
  • Ed Dooley
    September 20, 2006 at 8:12 pm
    Just in case you don’t know, *all* firewire ports use the same bus, so when you say you only have
    the AJA connected to the FW port, do you mean to *any* FW port, or just the one the AJA is connected to?
    If you have another FW device connected to another internal FW port, it’s really using the same FW as your
    AJA.
    Ed
  • Morten Raarup
    September 21, 2006 at 6:36 pm
    io is the only thing on fw ports ,400 and 800. I use a Huge scsi raid as harddirve.
  • Ed Dooley
    September 21, 2006 at 6:58 pm
    If you follow Tony’s advice, go to the AJA site for the latest driver version.
    Sorry, I can’t think of anything else at the moment.
    Ed
    [tony salgado] “From you test in which you swapped a decklink into your mac I assume you have decklink driver installed also in addition to the AJA drivers?
    Clear out the BM drivers and if needed do a clean install of the AJA drivers, FCP and the Huge drivers if needed.”
  • Chris Tompkins
    September 23, 2006 at 12:05 pm
    And you’ve checked in FCP that the “Limit Capture to” is not selected….
  • Ed Dooley
    September 25, 2006 at 3:07 pm
    Since he can capture longer clips when using another card, it seems unlikely it’s that, unless that option changes
    when changing cards. :-).
    Ed
    [Chris] “And you’ve checked in FCP that the “Limit Capture to” is not selected….”
