invisible outside, video inside a tube
hi got a question. I am wanting to make a transition where you go from looking at a logo, to camera zooming toward a scope, then entering the scope and traveling down the inside of the tube. I need a couple of things.. one to make the outside of the tube invisible to the camera, so its not seen before the transition, two..the inside of the tube needs to be very shiny and reflective, and I need some object at the end of the tube that will let in some light, and also be something I can throw a video on, so you see the video playing and coming closer as you travel down the tube. got the tube setup, and the camera travels down it ok. just need some suggestions on the rest of it. Thanks
