Activity Forums Zaxwerks Invigorator won’t see my text
  • Invigorator won’t see my text
    Posted by Mark Volzer on October 7, 2006 at 4:38 am
    Ok so I’m animating a logo and using Invigorator, but it won’t recognize my text. It says there are no usable paths, but I have already converted the text to paths (create outlines) in Illustrator. Is there a compatibility problem between Illustrator CS, AE 6.5 and Invigorator?
    Jon Okerstrom replied 19 years, 11 months ago 2 Members · 3 Replies
  • Jon Okerstrom
    October 7, 2006 at 12:38 pm
    Mark,
    My first guess is that you need to resave the Illustrator (text converted to outlines) file in Illustrator format, but be sure the “use compression” check box is unchecked.
    Jon
  • Mark Volzer
    October 9, 2006 at 6:33 am
    Still doesn’t see it. I know that invigorator like files in illustrator 8 (or at least it used to) could that be the problem?
  • Jon Okerstrom
    October 10, 2006 at 12:02 am
    Mark,
    What version of Invigorator are you using? Older versions do require legacy Illustrator files.
    Send me your file if you want. jokerstrom1 (at) mac.com.
    Jon
