Activity Forums Zaxwerks Invigorator Set-up window shows nothing
  • Yymmij
    April 11, 2006 at 9:41 am
    I don’t think it is a setting. My guess is that 10.4.6 may be the culprit. I get the same results. Was working fine a few days ago, and OSX 10.4.6 is the only thing that has happened between then and now.
  • Ianmarcias
    April 11, 2006 at 3:55 pm
    I’m currently using Windows XP. It just stopped working for me too. I hope I can get a fix. I’m currently working on a project that desperately needs it.
  • Matt Rhodes
    April 18, 2006 at 12:21 am
    Hi.
    Thanks for posting a screenshot. It seems that the OpenGL driver is not
    being properly created for the Set-Up window. It’s good to see that the
    OpenGL preview in the Effect Controls Window (ECW) is working.
    Had the Invigorator previously been working for you? Do you know which
    version you last used?
    For those having trouble, please email me your system information (including
    which graphics card you’re using) along with which version of the Invigorator
    you’re using. I’ll try to see if there’s a common thread — and I’ll try to
    duplicate the problem here.
    Thanks a lot.
    Matt Rhodes
    Zaxwerks, Inc.
    matt@zaxwerks.com
