Invigorator Pro constantly crashing in Creative Cloud 2015
Posted by Cliff Wallace on August 27, 2015 at 9:09 pmEver since I upgraded to CC2015 and the latest cut of Invigorator Pro, I am getting constant crashes when I close out of the Invig Pro project window to go back to After Effects. It seems to be happening the most when I’m using texture maps, reflection maps and bump maps. It doesn’t seem to matter if the map is coming from an image or a layer map. Anyone else having these issues? Before the upgrade Adobe and Zaxwerks seemed to work really well with each other. Now, not so much. Any advice how to make this stop?
Rob Mize replied 9 years, 11 months ago 4 Members · 17 Replies -
Alex Dow
September 1, 2015 at 7:43 pmHi Cliff,
I’m sorry to hear your getting crashes. We’ve had a couple users on windows machines that are running into the same issues. Are you also running a windows machine? We are currently working on a fix, but In order to find a solution quicker it would be helpful to get more information.
Please email me at support(at)zaxwerks.com with this info:
1. Computer Specs
2. If the program crashes please send me the crash logs:Windows Instructions
1. Click Windows Start button > Type event in Search programs and files field.
2. Select Event Viewer
9213_image001.png.zip3. Navigate to Windows Logs > Application, and then find the latest event with “Error” in the Level column and “Application Error” in the Source column
4. Copy the text on the General tab.
5. Open Notepad, paste the text, and then save the log as .txt.
6. Or you can take a snapshot of the entire screen and save as a .jpg file.
Steps to take a screen shot:
a) To take a screen shot, press the “Prt Scr” key on your keyboard when you encounter this error.
b) Then go to Start > Programs > Accessories > Paint.
c) Paste the screen captured there by pressing “Ctrl+V” or Alt+Edit+Paste.
d) Save the file as a .jpeg and then send it to us for analysis.
7. Send the log (.txt or .jpg) to me as well as the project that you were working with.3. Please send me any project files that you are working with when you receive the crash.
Thanks for your help.
Cheers,
Alex Dow
Tech Support/Customer Service
Zaxwerks -
Cliff Wallace
September 1, 2015 at 9:20 pmI’m working on Mac and it crashes on pretty much any project that I try to add a layered or image texture to or if I try to change an existing texture with a different layered or image file. I also have been having the same issues with bump maps too. Where should I email the info and files?
Cliff Wallace
October 15, 2015 at 9:41 pmHas there been any resolution to this issue? My Invigorator Pro still crashes when I try to use the Layer Maps function. It doesn’t do it every time, but does it often enough to make the product almost unusable. Some help would be appreciated.
Alex Dow
October 15, 2015 at 10:17 pmHi Cliff,
We’ve found that some user’s graphics cards are causing the issue. Inside of the setup window go to Help > Preferences…
Uncheck the item named “Use GL Shaders in Draft Mode”.
Also what are your system specs?
Alex Dow
Tech Support -
Cliff Wallace
November 19, 2015 at 11:11 pmHi Alex,
Sorry, just remembered this. I tried your suggestion, but still had the same result. Any other suggestions?
My computer’s specs are:
Mac Pro running OSX Yosemite 10.10.5
2.7 Ghz 12-Core Intel Xeon E5
64 GB of 1866 MHZ DDR3 ECC
AMD FirePro D5000 3072 MB Graphics card -
Alex Dow
November 20, 2015 at 7:41 pmHi Cliff,
Thanks for the info. What specific steps are you doing when the program crashes? Are you just simply applying the plug-in and it crashes?
Alex Dow
Tech Support / Customer Service
Zaxweks
alex(at)zaxwerks.com -
Cliff Wallace
November 20, 2015 at 7:52 pmNo, it happens after I apply an image or layer map to a texture and apply it to the model in the edit window. It always crashes when I click out of the Zaxwerks edit window back into After Effects. It hangs up for a few seconds like it’s trying to render the image preview, then crashes After Effects. It’s very consistent in doing that and does it whether I apply an image or use a layer map assigned from the comp. Doesn’t matter.
Cliff Wallace
November 20, 2015 at 8:19 pmSomething I just noticed is that when applying the layer map or picture map to the texture I was selecting “Absolute Color” and when I left it on “Standard Color” it didn’t crash. Then I selected “Absolute Color” and it crashed again. So maybe the issue is found in that process. FTR, I use “Absolute Color” most of the time because I want the texture to be true to the image I’m mapping.
Cliff Wallace
January 18, 2016 at 11:20 pmChecking in to see if there has been a fix for this yet. The work-around that we talked about a couple of months ago (using it in Ray Tracing Mode) isn’t having any effect on my current project. Still getting crash after crash. Please help!!!
