Activity Forums Zaxwerks invigorator HD
  • invigorator HD
    Posted by Adeeb Oberoi on July 28, 2008 at 5:06 am
    I was wondering if I have to do a HD project, can I do it in NTSC widescreen and then before rendering change the comp settings to HD and then scale up the INVIGORATOR layer?
    Scott Novasic replied 18 years, 1 month ago 2 Members · 1 Reply
  • Scott Novasic
    July 28, 2008 at 5:58 pm
    the answer is yes as far as I know. You cant “render out” your invigerator content, THEN scale it up, that will result in a softening of your image. If the non rendered invigerator file is present and “in place” in the new HD comp it should render out as clean and nice as your D1 comp.
    Scott
    SuperNova
    Animation & Visual Effects
    Scott Novasic
    Los Angeles Ca
    web:https://web.mac.com/finaleffects
