Invigorator flickers screen
Posted by William Nellam on May 18, 2008 at 3:00 amIf I have the scene preview window open , Invigorator makes the menu bar of AE flicker. I have plenty of memory. I have no problem opening up the plugin and using it. Also I have no problems with Pro Animator. Is there a setting I should check?
William Nellam replied 18 years, 4 months ago 2 Members · 7 Replies -
Jon Okerstrom
May 18, 2008 at 7:42 pmWilliam,
I haven’t heard of this issue. Providing more info about software versions and system hardware may provide some clues.
Jon
William Nellam
May 19, 2008 at 1:03 amWindows XP Pro SP3
AMD 64 Processor 3800+ 1 GB Ram
2.41 GhzAfter Effects CS3 (Did it with previous version too)
Invigorator Pro 4.0 -
William Nellam
May 21, 2008 at 1:19 amMaybe I don’t need Invigorator if I have Animator Pro. Maybe since they are both installed its causing an issue.
Jon Okerstrom
May 21, 2008 at 2:11 amHi William,
I have no reason to believe one app would impact the other. By chance are you rendering interlaced video? If so, it can look like it “flickers” on progressive-scan monitors like your computer monitor. To see what’s happening for sure, try watching your video on the intended device.
Jon
William Nellam
May 21, 2008 at 9:53 pmNo this is not effecting the video I am creating. It like flickers the menu and the program controls like something is wrong. Like it wants to freeze up. But again since I have ProAnimator it does all the Invigorator does. So I guess I can just uninstall it.
Jon Okerstrom
May 22, 2008 at 12:28 amWilliam,
You could uninstall, but I wouldn’t suggest that.
ProAnimator and Invigorator share the same modeling and texturing abilities – for the most part. However, their animation controls and abilities are really not the same. Each has advantages in certain situations.
You might contact tech support for this issue.
Jon
