Invig Pro-custom edges not loading
Posted by Jim Wilcox on December 22, 2009 at 11:58 pmRunning Inv Pro 4.5.1 in AE CS3. I cannot seem to get the custom edges to update. I have drawn new edges and saved them, even turned off all other edges in the custom edges document, but reloading does not change out any edges. Am I missing something basic?
Edward Wu replied 16 years, 8 months ago 3 Members · 5 Replies -
Serge Hamad
December 23, 2009 at 3:29 amHi Jim,
Where are you saving your Custom Edges? I think since a year or so you need to save them in a different folder then the older versions.
Here is the path for Windows:
C:\Documents and Settings\ADMIN\My Documents\Zaxwerks\3D Invigorator PRO\Custom EdgesDoes this help?
Salut.
SergeNew! InvigoMany-Media volume I & II available here:
https://www.nyc-visual.comInvigorator/Proanimator Training: https://library.creativecow.net/articles/hamad_serge/invig_training.php
Jim Wilcox
December 23, 2009 at 5:05 pmSerge,
Thanks for the info. I am on a mac, but I found where the custom edge doc is that is being read. Considering how you install the invig plug, how does that even get there?
Jim
Edward Wu
December 23, 2009 at 5:11 pmHi Jim,
In the newer versions of our software, all swatches are copied into the Documents folder to let users have access to a set of “User Swatches” while the “Master Swatches” are preserved. This way, if you ever need to reset your swatches, just delete the Invigorator Pro folder in the Documents folder, and the swatches will be rebuilt from the Master swatches.
Best,
Edward
