Activity Forums VEGAS Pro Invert cookie cutter property on all keyframes at once
  • Invert cookie cutter property on all keyframes at once
    Posted by Fabio Mereghetti on January 15, 2012 at 8:20 pm
    Hi.
    I created an animated circle with cookie cutter to follow an athlete while she is doing a performance of artistic gymnastics.
    Now I would like to change only the property “cut away all but section” with its opposite “cut away section”: is there a way to do that without having to step through all the single keyframes?
    If there is not, can I “convert” the animated CC into a mask, somehow, and then invert it?
    Thanks.
    John Rofrano replied 14 years, 7 months ago 2 Members · 1 Reply
  • John Rofrano
    January 16, 2012 at 2:38 am
    [fabio mereghetti] “Now I would like to change only the property “cut away all but section” with its opposite “cut away section”: is there a way to do that without having to step through all the single keyframes?”
    No. That’s one of the limitations of keyframing; you need to change every keyframe individually.
    [fabio mereghetti] “If there is not, can I “convert” the animated CC into a mask, somehow, and then invert it?”
    No, there is no way to directly convert a CC into a mask but you could apply the CC to a piece of white generated media and then use the Masking function of the Track to create a black and white mask. This might work.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
