Activity Forums Adobe After Effects Expressions inversing scale percentage
  • inversing scale percentage
    Posted by John Lacroix on December 6, 2007 at 11:49 pm
    If any of you have watched the Demon face tutorial by Andrew Kramer, you’ll know what I’m talking about here. He shows how to stabilize footage and then reverse that stabilization later but he only tracks position and rotation.
    What if you also track the scale?
    My question is, what should the math of the scale expression look like to reverse the effects of the scale created by tracking/stabilization. For example if on whatever frame the object in my precomp is 150% what math do I need to make it 66.66%?
    I had a programmer friend help me and we came up with this to make it work:
    [10000/comp(“TRACKED”).layer(“PRE TRACK”).transform.scale[0],10000/comp(“TRACKED”).layer(“PRE TRACK”).transform.scale[1]]
    but is there a easier way?
    John Lacroix replied 18 years, 9 months ago 2 Members · 2 Replies
  • Dan Ebberts
    December 7, 2007 at 2:30 am
    Well, you could pretty it up a little, like this:
    s = comp(“TRACKED”).layer(“PRE TRACK”).transform.scale;
    [1/s[0],1/s[1]]*10000
    Dan
  • John Lacroix
    December 7, 2007 at 5:03 am
    Yes! That’s a nice cleaner way to do it. Thank you!
