Activity › Forums › Maxon Cinema 4D › inverse light fall off
  • inverse light fall off
    Posted by Eric Sanderson on July 1, 2011 at 8:27 pm
    2 posts in a row i know, busy day. Ive been looking online but cant find an answer. For this same bathroom interior ive been following a DT tutorial for lighting and rendering interior scenes. And just got to a point where he chooses “Inverse” light falloff from his drop down menu, and i dont have that option, along with many other options he has. Im using c4d r12 so im guessing hes on an older one sicne i know c4d seemed to “consolidate” a lot of features in r12. So how can i achieve this inverse fall off space? Has it moved or am i forced to just find work arounds to achieve the look?
    Adam Trachtenberg replied 15 years, 2 months ago 3 Members · 6 Replies
  • Tim Shetz
    July 1, 2011 at 9:03 pm
    Under falloff, you don’t have inverse-square?
    Are you using r12 Studio?
    __________
    Tim Shetz
    c4dtraining.com
  • Eric Sanderson
    July 2, 2011 at 12:03 am
    Ya i have inverse square, and inverse square clamped, but what i want is simply “inversed” like previous versions have. inverse squared tends to blow lights out at the source.
  • Tim Shetz
    July 2, 2011 at 12:56 am
    Hmmm, I’ve always used inverse square since it is how light really falls off. Never had a problem with it blowing out the lights. I just adjust the light visibility settings and the falloff….
    What type of light are you using? ie visible,volumetric, etc.
    __________
    Tim Shetz
    c4dtraining.com
  • Adam Trachtenberg
    July 3, 2011 at 4:12 am
    True, inverse square is the realistic choice. Blowout is less of a problem than it used to be if you are using linear (gamma) workflow.
  • Eric Sanderson
    July 5, 2011 at 2:32 pm
    I actually am using linear (setting gamma to 2.2 right?). For my future scenes ill keep into consideration using inverse square, just for the moment though im following a tutorial trying to improve my lighting and rendering skills and reached a step that they used just inverse, which in his scene improved it a lot so for now was just trying to do that for the sake of following along.
  • Adam Trachtenberg
    July 5, 2011 at 7:35 pm
    Linear means a gamma of 1. In R12 all you have to do is check the linear workflow box in project settings. That takes care of everything except your eventual output settings.
