Activity Forums Adobe After Effects Intersecting particles
  • Intersecting particles
    Posted by Menno Wisselink on July 15, 2015 at 3:38 pm
    Got This;
    – Three particular layers following 3 different Emitters which are going (by a wiggle) in Z space.
    Problem is that the 3 layers are not interacting with eachother… : I cant seem to fix the intersecting you see in the picture above..
    Anyone got a solution?
    Menno Wisselink replied 11 years, 2 months ago 2 Members · 2 Replies
  • Kevin Camp
    July 15, 2015 at 8:11 pm
    to get interaction int 3d space, you’ll need to use lights as emitters and a single instance of particular.
    it looks like you’d want to create 3 lights. each needs to be named with “Emitter” as a prefix — ex: Emitter1, or EmitterRed, etc. and each with the wiggle expression used to drive your current emitter positions.
    color will be determined by the color of each light, rather than the color property of the particle.
    lights can control other particle properties, look up some tutorials that use lights for emitters for more info on that.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Menno Wisselink
    July 15, 2015 at 9:08 pm
    Thanks Kevin Camp! Thanks for the tip!
