Activity Forums Adobe After Effects Intersecting 3D Shapes and Text
  • Kalleheikki Kannisto
    June 5, 2019 at 2:59 pm
    In that image, you have lines that are on separate layers which are blended in difference mode. They are not actually intersecting on the same layer. The plexus effect is on top of this, not intersecting anything.
    Senior Graphic Designer
  • David Matthew
    June 5, 2019 at 8:19 pm
    Thank you so much ☺ . I was getting worried that I won’t be able to get it.
