Activity › Forums › Apple Final Cut Pro Legacy › Interruption on the cuts after rendering in final cut
  • Interruption on the cuts after rendering in final cut
    Posted by Annebelle Van zweden on June 8, 2008 at 11:44 am
    Hello,
    I have a problem with rendering in final cut. When I make a render then there are a sort of interruptions between the shots. On the cuts of the shots one shot shines through the other and you see also cubes.
    The cuts are just straight and I used no filters/effects and the renders are uncompressed (to work with it in after effects). My sequence and render settings are ok I guess. I work with a pixel ratio of HD (1440×1080)(16:9).
    Also when I make the shots untight of each other and render a single shot then you see the same interruption at the begin after rendering (the shot before shines through and the cubes). And that’s so strange because now the shot is untight of the shot before.
    In my projects is everthing fine, you see nothing strange, so it’s only after rendering.
    Does anybody know what this problem is and how I can fix it? I would be very thankful!
    Greetz Annebelle (Sorry for my english, it’s not very good I guess)
    Annebelle Van zweden replied 18 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
