Activity Forums Adobe After Effects Interpreting D1/DV NTSC (.09)
  • Interpreting D1/DV NTSC (.09)
    Posted by Todd Carter on August 15, 2005 at 3:31 pm
    I can’t seem to find the answer here…I export some D1 footage from FCP 5… and just export it with “current settings”. I then import it into AE 6.5. I “interpret” the footage and it somehow always shows up as Non-Square (.091:1). I then interpret it to be D1/DV NTSC (.09) again, but am wondering is this correct? It makes sense that the footage needs to be D1 for input back into FCP, but is this a viewing issue only in AE? Thanks!
    Todd Carter replied 21 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
