Activity › Forums › Adobe After Effects › Interpolation problem
  • Interpolation problem
    Posted by Augusto Garcia on September 26, 2013 at 12:16 am
    Hey, my first post.
    I’m trying to do some advanced lip syncing for a cartoon character, and I will narrow it a bit down here to explain my problem.
    I’ve seen some lip sync tutorials that use time remapping on a precomp, which works fine if you want different static mouths representing the different sounds.
    But I’m gonna be difficult and demand interpolation! In other words; I want the mouth shape to be able to go from A to C, without going through B, and I want interpolation between A and C.
    Can it be done?
    Thanks! ;D
    Augusto Garcia replied 13 years ago 2 Members · 2 Replies
  • Todd Kopriva
    September 26, 2013 at 2:46 am
    Yes, you can interpolate between paths, such as from one mask path to another or from one shape path to another. Just set keyframes for a path property, and interpolation will happen between the keyframes as with any other property.
    After Effects team blog
  • Augusto Garcia
    September 26, 2013 at 5:23 pm
    Thanks for the reply Todd!!
    Another doubt I have, is possible to do interpolation between layers,for example, create a mouth rig and go to A from C,without going through B?
    Thanks! ;D
