Activity Forums Adobe After Effects interpolated vertices/anchorpoints of shape path
  • interpolated vertices/anchorpoints of shape path
    Posted by Alfred Steiner on July 19, 2015 at 7:02 pm
    Hello,
    Does anyone know where this vertex/anchor point of my animated shape path is coming ?
    i think it has to do with some keyframe interpolation, anyways is there a way to disable it?
    i just found out that the number of these vertices (which are only visible if the cursor is between the keyframe) equals the number of vertices which are added in the next keyframe… but I still dont know avoid them.
    I made a script to manage it somehow but thats not the best solution. Id prefer a non script option.
    // G L O B A L S
    var theComp = app.project.activeItem;
    var theLayer = theComp.layer(1);
    var thePath = theLayer.property("ADBE Root Vectors Group").property("ADBE Vector Group").property("ADBE Vectors Group").property("ADBE Vector Shape - Group").property("ADBE Vector Shape");
    for (var i = 1; i <= thePath.numKeys; i++) { var getVerts =thePath.keyValue(i).vertices; if (getVerts.length > 2) {
    for (var n = 0; n < (getVerts.length-2); n++) { // Mittelpunkt zwscihen Vertex n und n +2 berechnen var middle_x = getVerts[n][0]-((getVerts[n][0]-getVerts[n+2][0])/2); // absolute differenz between x = coordinated var middle_y = getVerts[n][1]-((getVerts[n][1]-getVerts[n+2][1])/2); // überprüfen ob der dazwischenliegende Punkt dem errechneten Mittelpunkt entspricht var test_x = Math.round(getVerts[n+1][0]); var test_y = Math.round(getVerts[n+1][1]); if (Math.round(middle_x) == test_x && Math.round(middle_y) == test_y) { //alert("found"); getVerts.splice((n+1),1); n--; } } } var myShape = new Shape(); myShape.closed = false; myShape.vertices = getVerts; thePath.setValueAtKey(i,myShape); }
    have a nice day,
    Alf
    Alfred Steiner replied 11 years, 1 month ago 53,371 Members · 2 Replies
  • Alfred Steiner
    July 21, 2015 at 10:36 am
    Ah okay i didnt know this. Is there another possibility than using Hold Keyframes if i want to avoid any interpolation?
  • Alfred Steiner
    July 22, 2015 at 9:23 am
    Hi okay then I will describe it.
    i have a 30 fps Video of rain drops falling into a puddle. now I begin in the first Frame and look where the first rain drop hits the ground. From this point i want a line to be drawn to the second drop which hits the ground and from this one to the third and so on.
    so over the frames the lines evolve to a graphic.
    i hope one can understand this.
    regards,
    Alf
