Activity › Forums › DaVinci Resolve › Interpolate between Dynamic Keyframes
  • Interpolate between Dynamic Keyframes
    Posted by Randy Rubin on February 6, 2015 at 9:05 pm
    Hi There,
    I have two dynamic keyframes and I am try to animate my primary correction. Instead of interpolate between the keyframes, the correction changes when it hits the second keyframe.
    I’ve made sure both keyframes are ‘dynamic’. Am I missing something?
    Tiphaine Buccino replied 11 years, 1 month ago 4 Members · 3 Replies
  • Margus Voll
    February 8, 2015 at 9:58 pm
    Seems lik a bug to me.
    I have had this many times.
    In any case try to zoom in as much as you can to see it not double keyframes in one spot
    1 frame a part.
    Margus
    https://iconstudios.eu
    Resolve 11
    BMC 2,5k
  • Sascha Haber
    February 9, 2015 at 8:40 am
    Yes, i had the same problem here and there.
    I happens when you have two keys , cut the clip and place a third one then in the middle , for example.
    That is one of the reasons why we need a proper keyframe editor.
    We all make dumb mistakes but it would be good to look at it after and be able to fix it.
    If the situation here occurs i tend to break the shot and just add a dissolve between the two grading points.
    Which has way more control and you don’t have to worry about any keyframes 🙂
    Resolve 11.2 – Smoke 2015 EXT1SP2 – Sapphire 8
    Colorist / VFX Guru / Aerial footage nerd
    https://vimeo.com/saschahaber
    https://dk.linkedin.com/in/saschahaber
  • Tiphaine Buccino
    August 8, 2015 at 10:07 am
    Thanks a lot guys ! You save me from a nightmare !!
