Activity Forums Apple OS X internal hard drive not showing up: what are my options???
  • internal hard drive not showing up: what are my options???
    Posted by Nick Natteau on March 10, 2014 at 5:23 pm
    After not seeing my secondary internal hard drive on my 2008 MacPro desktop running Mavericks, I first verified that “hard drives” were checked in the Finder window.
    Then I ran Disk Utlity and discovered this:
    What can I do to make the computer see the hard drive?
    Desperately hoping that formatting the drive is not the only option left.
    Al Bergstein replied 12 years, 2 months ago 3 Members · 2 Replies
  • Chris Murphy
    March 11, 2014 at 5:53 pm
    One drive missing usually means it has failed or has been disconnected. Since this is raid0 (striped set) that would mean the entire volume is useless which is why it’s offline. Formatting is not going to fix this.
    Disk Utility RAID user interface is really screwy, so confusion is normal. But in recent versions you can click on physical drives (not volumes or raid sets as you have done here) and click the Info button in the tool bar, and find the SMART status which should give you an idea if the drive has in fact failed or not.
  • Al Bergstein
    March 17, 2014 at 6:56 am
    Nick, what did you find out about your failed RAID?
    Al
