Activity › Forums › DaVinci Resolve › intermittent middle click copy grade crash bug?
  • intermittent middle click copy grade crash bug?
    Posted by Andrew Sableton on July 12, 2012 at 7:51 pm
    Wondering if anyone else has this issue…..
    I find that there are certain saved stills that will very often crash Resolve when I use the middle button on my mouse to copy them to the current clip in the timeline.
    Most of the time this technique works fine…..but there seem to be a few particular saved grades that will crash my system more than 50% of the time I try to use them. With these particular stills if I apply the grade by dragging them into the node window, the crash does not happen. I think I am also finding that if I hold down the middle click button for a moment, rather than immediately releasing after clicking, the crashes do not seem to be happening…..
    This is very annoying as I had over 20 crashes yesterday due to this issue. It is also slowing me down as I am saving much more often than usual in order to not lose too much work when the crashes happening…
    S
    Dwaine Maggart replied 14 years, 2 months ago 3 Members · 2 Replies
  • Kevin Cannon
    July 12, 2012 at 8:21 pm
    I was having this problem which seemed pretty random, but eventually i realized for me it was happening only when in “Unmix” mode in 8.1 or 8.2. I don’t remember the exact release but it was solved in a subsequent one.
    KC
    Prehistoric Digital
  • Dwaine Maggart
    July 13, 2012 at 2:51 am
    Copying grades in Unmix mode will crash Resolve unless you are using 8.2.1 beta 3 or higher.
    When this happens to you, are you in Unmix mode?
    Dwaine Maggart
    Blackmagic Design DaVinci Support
