Activity Forums Apple Final Cut Pro Legacy Intermittent glitch on capture
  • Intermittent glitch on capture
    Posted by David Scott on June 22, 2006 at 9:21 am
    Hi
    I have recently began experiencing problems with an ocassional glitch during capture – Beta SP or DVCpro25 through AJA IO to FCP5 8bit uncompressed. FCP does not report a problem but playing back the clip, suddenly there is a 10ish frame picture freeze then it continues, but the audio is unbroken, so that after the glitch they are out of sync to the end of the clip. I suspected the SPG, but have changed that and still have the issue. It happens with either deck, so that leaves AJA, MAC, or Drive.
    Has anyone seen this fault before?
    Many thanks
    David
    David Scott replied 20 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
