Activity Forums Avid Media Composer Interlacing Problems With MPEG2 PAL
  • Interlacing Problems With MPEG2 PAL
    Posted by Mike Burchett on December 6, 2006 at 11:47 pm
    Hi Everybody,
    We got a file that was uploaded in the U.K. and we’re having some
    problems with it. It’s MPEG2 file in PAL and we’re trying to
    intergrate it with our NTSC stuff and that’s where the problems are
    occuring. I was able to convert it to NTSC just fine and DVD Studio
    Pro and AVID XPress Pro are opening the file just fine but there are
    major interlacing and artifacting problems.
    The interlacing and artifacts are also in the original MPEG2 PAL file
    which we were able to open with Quicktime Pro and when you step frame
    by frame you can see all the lines when any sort of movement is
    involved (which makes me think that it’s an original compression
    problem).
    Do you have any ideas regarding this? Any input would be greatly appreciated.
    Mike Burchett replied 19 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
