Activity Forums Apple Final Cut Pro Legacy Interlacing Footage
  • Interlacing Footage
    Posted by Richard Johnson on May 1, 2011 at 9:57 pm
    I’m shooting some promotional material for a website and am using my Nikon D7000. I have it on a steadicam and while I’m happy with the footage for the most part, during pans and following a person walking around the test footage has a lot of flicker. I imagine this is much in part to the 30p frame rate. I don’t want a film look but more of a television, marketing look.
    Can I interlace the footage and will that help. I am converting the footage to pro-res through compressor. While I have the option to “de-interlace” the footage there doesn’t appear to be an option to “interlace” it. Is this possible? Would this help smooth the motion and have the footage seem to “flicker” less when moving? Thanks.
    Chris Tompkins replied 15 years, 4 months ago 5 Members · 6 Replies
  • Jerry Hofmann
    May 1, 2011 at 10:58 pm
    You can’t interlace footage shot progressive. Describe the flicker, and post the exact settings you used to transcode the footage to ProRes.
    Jerry
  • John Heagy
    May 1, 2011 at 11:07 pm
    You also should never put interlaced footage on the web… only progressive.
  • Richard Johnson
    May 1, 2011 at 11:16 pm
    Don’t know exactly which settings you mean. In “Compressor” I chose Apple Pro Res 422 for progressive. Here is the compression summary:
    “Apple ProRes 422 for Progressive material
    Description: Apple ProRes 422 10-bit video with audio pass-through. Settings based off the source resolution and frame-rate.
    File Extension: mov
    Estimated file size: 772.62 MB
    Audio: multi-track passthrough
    Video Encoder
    Format: QT
    Width: (100% of source)
    Height: (100% of source)
    Selected: 1280 x 720
    Pixel aspect ratio: Square
    Crop: None
    Padding: None
    Frame rate: (100% of source)
    Selected: 29.97
    Frame Controls: Automatically selected: Off
    Codec Type: Apple ProRes 422
    Multi-pass: Off, frame reorder: Off
    Progressive
    Chroma filtering enabled
    Pixel depth: 24
    Spatial quality: 50
    Min. Spatial quality: 0
    Temporal quality: 0
    Min. temporal quality: 0”
    The file started as a 135 MB .MOV quicktime movie from my digital SLR.
    The flicker I am referring to is most visible while making a turn with the camera on the steadicam. I think the answer is to turn more slowly and try to incorporate stationary tripod shots whenever possible. I could also pull out the dolly and retain motion, but smoother and with more control. It’s just a pain to lay out the tracks and bring additional gear. At 30p the jerkiness is not as bad as 24p. I just wish the Nikon D7000 offered 60p in 1280×720 mode. Any ideas?
  • David Roth weiss
    May 1, 2011 at 11:24 pm
    [Richard Johnson] “The flicker I am referring to is most visible while making a turn with the camera on the steadicam.”
    How are you monitoring your ProRes video? Not on QT Player I hope? Because it doesn’t run at speed.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • Richard Johnson
    May 2, 2011 at 12:57 am
    Watching through final cut pro. I’m just viewing test footage right now. I was actually impressed with how much better 30p did compared to 24p. It was noticeable and I didn’t think it would be. Anyway, I think I will be able to get by, I was just hoping their might be some post production help since my camera doesn’t offer higher frame rates.
  • Chris Tompkins
    May 2, 2011 at 10:38 am
    ya, 30p will still have some of that stutter on pans.
    Chris Tompkins
    Video Atlanta LLC
