Activity Forums AJA Video Systems Interlacing
  • Interlacing
    Posted by Jason Collier on June 22, 2009 at 2:26 pm
    Anyone have interlacing issues when capturing with a AJA Kona card. I see small horizontal lines when pausing the action and when there’s alot of movement (hand waving, mouth moving etc). I understand the whole interlacing concept, and when I pause video I can see some banding, but sometimes this comes across when playing the video. Also we have 2 avid systems here and they don’t show this same banding. If I deinterlace then the banding goes away, but the edges of things get stair-steppy.
    Joey Burnham replied 17 years, 2 months ago 3 Members · 2 Replies
  • Jeremy Garchow
    June 22, 2009 at 3:35 pm
    What format are you capturing from and what codec are you capturing to? Where are you looking at this material on your computer monitor or a proper broadcast monitor?
    When in pause, you have the option to look at both fields or a single field in the AJA control panel.
    JEremy
  • Joey Burnham
    June 26, 2009 at 6:22 pm
    [Jeremy Garchow]
    When in pause, you have the option to look at both fields or a single field in the AJA control panel.”
    Yep. Under the codec tab you can switch this. But personally I would leave it how it is. Much easier to not get flash frames when editing.
    Joey
